Anyone Make 2.XX Gears For 9" Rear Ends?
Old 09-06-2009, 09:58 PM
XpEdItIoUs's Avatar
Default Anyone Make 2.XX Gears For 9" Rear Ends?
Dose anyone know where I can get 2.xx gears for my moser 9"?
Old 09-06-2009, 10:32 PM
1320's Avatar
Im not sure what 2.xx is?
They are around all the way to 2.41. 2.41 are used, not available new anymore. Not really a problem though, ussually 25-100$ and teh higher the gear the stronger they are....so basically you cant break a used stock 2.41 gear no matter what.
2.75's that are in zombiess turbo car, were $25 off ebay.....They have several hunderd 10.00 to 10.80 passes on them and a bit of street miles. A good $25 .
Old 09-06-2009, 10:45 PM
JeaneZ28's Avatar
I dont think they go lower than 3.00
Old 09-06-2009, 10:46 PM
XpEdItIoUs's Avatar
2.XX means any number for the .XX, 2.75's is what im looking for but had no luck finding anything under a 3.00
Old 09-06-2009, 10:50 PM
JeaneZ28's Avatar
what spline?
Old 09-06-2009, 10:55 PM
XpEdItIoUs's Avatar
Originally Posted by JeaneZ28
what spline?
I have 35 spline axles.
Old 09-06-2009, 10:56 PM
JeaneZ28's Avatar
They make 2.80 but its for a 28 spline. It looks like 3.00 is the lowest you can go with a 35.
Old 09-06-2009, 11:06 PM
XpEdItIoUs's Avatar
That's pinion spline, It dosn't matter since I can get a pinion yoke for them if I have to.
Old 09-06-2009, 11:11 PM
XpEdItIoUs's Avatar
what spline?
Sorry for some reason i thought you asked what axle spline, Im not sure on my pinion yoke spline i forgot.
Old 09-06-2009, 11:24 PM
JeaneZ28's Avatar
Here the one for the 2.86
http://www.summitracing.com/parts/RMG-4901061/
I couldnt find a place that sold the 2.80 but you may be able to get them from richmond directly.
Part Number
49-0107-1
Old 09-06-2009, 11:51 PM
Awake455's Avatar
I've found OEM 2.50 and 2.41 gears on several occasions. Couldn't tell you the pinion spline count off of the top of my head. It was never an issue finding a 1350 yoke to go on them is all the guidance I can give on that.
Old 09-07-2009, 09:40 AM
1320's Avatar
http://cgi.ebay.com/ebaymotors/FORD-...5#ht_500wt_924
275's right there.....for 60$...........
1320's Avatar
Old 09-09-2009, 05:17 PM
SS DNA's Avatar
Why do you want such a low gear ?
Boost ?
Old 09-09-2009, 06:05 PM
1320's Avatar
Ummmmm thats a high gear....
Old 09-09-2009, 10:37 PM
XpEdItIoUs's Avatar
Boost ?
So i can drive my car on the hwy with my th400.
Old 09-10-2009, 11:01 AM
DannoWS6's Avatar
You can get a 3.25 from moser and with a 28" tire it wouldn't be too bad at all doing 65mph. Gear that tall would be loose as **** with a nonlocked converter anyways. Unless your making over 1000hp I wouldn't put a gear below 3.00 in my car.
Quick Reply: Anyone Make 2.XX Gears For 9" Rear Ends?
