methanol controllers
I would say they are worth it. I have the alkycontroll kit and it comes with a progressive controller. It gets its readings from the map sensor, so as it sees more boost it sprays more methanol. I would think thats better than just spraying all the methanol at once via a hobbs switch.
I don't have any experience with the new progessive controllers that Snow Performance now offers but I'd check those out and see what you think about them. I've got the older non-digital version of the boost referenced progressive controller and it works just fine for me. I don't remember the exact settings I currently have it set to but I know that it activates at 2psi and should be a full power around 6 or 8psi max
yes every nickel.
check this controller out, it works and is reliable.
http://www.labontemotorsports.com/store/index.php
