alternator pulley!!!
Old 09-12-2009, 12:13 PM
19BLACKBIRD99's Avatar
Default alternator pulley!!!
How can I get this off, because every time I try it just spins the hole belt, need some help! thank you
Old 09-12-2009, 10:45 PM
Monkey_fuerte's Avatar
What exactly are you trying to do? Are you trying to get the pulley off the alternator?
Old 09-13-2009, 12:50 AM
Yeahh, so I can put a better pulley on along with my under drive pulley lol
Old 09-13-2009, 01:08 AM
spy2520's Avatar
you need high speed, like an air ratchet or impact gun. If you use an impact gun you can dont need the belt on, problem is you probably dont have room. Air ratchet will get it done on the car but the belt needs to be tight. otherwise you could probably hold it with a strap wrench or use a belt you wouldnt mind screwing up, hold it tight, hit it with the air ratchet. Good luck using hand tools.
Old 09-13-2009, 07:25 AM
Ph.D. in HUBRIS
custm2500's Avatar
The only easy way is to use an impact. If you don't have one take it to a shop and they would hopefully loosen it for you for no cost. If you choose to do this take 5 bucks and give it to the mechanic. We have people come ask for this kind of **** all the time and they don't tip you so then you don't want to do it next time.
As far as hand tools good luck but about the only way I see it is if you have a strap wench and then it still might be rather hard.
Old 09-13-2009, 07:26 AM
jomomma's Avatar
your probably going to end up taknig the alternater off the car and hitting it with an impact gun. its a pain in the *** but its about the only way i see doing it unless you get lucky with a strap wrench.
Old 09-13-2009, 01:49 PM
Yeahh I already had most of the alternator off lol so I guess I should just go ahead and finish it up lol now what about the underdrive?
Old 09-13-2009, 02:47 PM
1A Dan's Avatar
A lot of auto part stores have electric impact guns that they use to swap pulleys on alternators they sell. should be able to get them to swap it for ya for free. Used to do it all the time when I used to work for Advance Auto.
Old 09-13-2009, 05:15 PM
I got the alternator out and the pulley off and reinstallled and now I need help gettin the under drive pulley off
