View Poll Results: keep cetercaps or ditch em
Voters: 23. You may not vote on this poll
New wheels bigs and littles
got my new set up wish i would have went with a 15x10 in the rear instead if an 8 to fit bigger then a 275 but o well at least its a 28" tire. i need your opinions one side has it with the center cap other with out which is better i will paint the middle of the hub black if i leave them off
new pics
new pics
I have the same wheels as you and have been been doing some searching....one person said how they put there weld center caps on and they looked great. Said they were a tad loose until they torqued down the wheel then they were good to go. The difference in diameter between the summit cap and weld cap is like .100" or so. I'm going to grab some Weld caps off ebay or something because the Summits just dont cut it for me.
hmm how do these wheels fit compared to the weld wheels and whats the back spacing used on the rear and front my guess the fronts are 15 /3 and a 1/2 i like the look of those.
So if i put 275/60/15 u should have a fat *** look in the back i was thinking 315s ?? hey whats the back spacing for an 84 camaro, i want to get welds for it but not sure of what back spacing would be thanks.
