tranny dipstick.... so stupid
I made the mistake of bolting up the tranny and the motor and everything, putting on the intake, and fuel lines and all the wiring before putting in the Tranny dipstick. I cannot for the life of me fit that F-in tube back in the hole, even with the tranny on the jack and the motor bolts loose to change the angle of the motor giving me more clearence from the firewall. Does anyone have any advice for getting it in OR is there some sort of conversion kit, with a flexable tube for sale???
Any help would be great...
yes that tube sucks getting in especially with the trans bolted to the engine. i wanted to kill that tube the 6 times i had to install it. lol The best way is to do it before anything gets bolted up like you realize now . It is possible to get it in with it bolted to the engine, its hard but not impossible.
What i did was take a 3/4in open end wrench and hold it above the flare on the tube and then tap the wrench with a hammer to seat the tube. lube it up first helps. it is a PITA to do and takes some patience.
is it possible that a 97' because its an LT-1 and a slightly different body style is a little different than my ls1 style. With the wiring harness and everything and the clearence to the firewall Im dyin. They even have a part where the tube is bent in to almost 1 cm thick to clearence between the motor(or bellhousing) and firewall.
i had to take the intake manifold and the oil pressure sending unit... i ended up kinking mine and had to beat it out... then it wouldnt bolt up... i had to put it in sideways, like the end closest to u is on the driverside... if that makes sense... i ended up working on it for three weekends... most frustrating thing ever... prlly the hardest part yet on my swap hahha.. whats a bitch is when u get it in and the bracket is no where near a hole to bolt into....
