How fast have you been or seen a 224/228 cam go?
Old 09-20-2009, 07:24 PM
Intercooler2's Avatar
Default How fast have you been or seen a 224/228 cam go?
3600 lb plus car? Any dyno numbers? Would like to know if the torque is up there to match unlike some of the large sticks.
Old 09-20-2009, 07:34 PM
chet3310's Avatar
That's the cam I just put in my vette last week. It pulls like hell now! It made 397/384 on what I was told a conservative dyno. Should be in the 11s no problem now so with that weight, probably low 12s?
Old 09-21-2009, 12:14 AM
transamfreak01's Avatar
my car with the tr226 went 12.1 with a 1.8 60ft. car weighs 3800 without me. it only put down 340rwhp on the dyno.... i was kinda upset
Old 09-21-2009, 02:56 PM
chet3310's Avatar
That sounds like a tuning issue......
Old 09-21-2009, 05:03 PM
TooLateVTEC's Avatar
I know a local guy running a 226 cam in a CETA T/A with NO headers, but a cat back, DR's and skinny's runs 7.9X in the 1/8th. Full weight, leather and even has the spare tire/jack still in the car.
Old 09-21-2009, 05:20 PM
Fatbum's Avatar
I'll let you know what I run with my 224/228 on 19inch Rims and street tires in my 3800+ GTO next Friday
Old 09-21-2009, 05:29 PM
MIGHTYMOUSE's Avatar
had a thunder 224 cam in my trans am when it was stock motor/6 speed.
i loved the way it drove, made 380hp and snagged a 11.74!
Old 09-21-2009, 05:39 PM
DNOBLE1's Avatar
I'm running a 224 w/581 lift and 1.8 rockers and 3500 lbs plus driver (still has jack and spare tire). So far it went 7.36 in 1/8 th. It's a comp. Cams custom grind from texas speed. I've been to track twice and had bad trans and converter first time and didn't have time to get shift points worked out before second trip. I think she'll get into the twentys at least. It's still pretty smooth idle.
Old 09-21-2009, 05:49 PM
TORCHD 02 TA's Avatar
I have a slightly larger came. Race weight was 3500 lbs, i made 419/385 and went 11.8 @ 119
Old 09-21-2009, 06:43 PM
chpmnsws6's Avatar
I did 180mph before backing down due to lack of runway. It had 190mph+ written all over it. This was with an LG G5 cam, home ported heads, a built bottom end, all stuffed into a 1999 FRC. More weight will actually help your car be more stable.
Old 09-21-2009, 07:05 PM
Soul TKR's Avatar
My 224R cam is giving me 446/416 right now... but I also have a 6.0 with AFR 205's
Old 09-21-2009, 07:31 PM
black00ssFL's Avatar
I've seen a bolt on, tr224 firebird go 11.8@119. M6 car, dr's, stock 10 bolt.
Old 09-21-2009, 07:41 PM
These are all good data points.
I have the cam but still think about the larger grinds. Just kind of scared if I opted to go larger it may not ET or feel as good. My race weight is 3800 so I can't really afford a cam that goes like 420/370
Old 09-22-2009, 02:25 AM
DiabloFormula's Avatar
Why don't you look into the Lunati VooDoo line like what I got, I know for a fact you'll see low 11's maybe even high 10's on your auto and I have there second to smallest cam and you've seen what my car does....lol
And plus you have enough of stall for a bigger cam.
Old 09-22-2009, 04:55 AM
One reason is the Comp Magnum 1.85's I am running. I like them and want to keep them. The other is I like the red light to red light torque and not having to spin it 6500 plus to make power. Third is just my fat car so I need a torque cam rather than just higher HP numbers. The cam I have will give me .581/.583 lift with my rockers and it's here.
Quick Reply: How fast have you been or seen a 224/228 cam go?
