Oil Filer Adapter Keeps Breaking
I just bought a wrecked 1990 silverado 1500 with 5.7L engine. The problem I am having is if you rev the engine at all the oil filter adapter cracks which causes the seal on the oil filter to break making quite a nice mess in my shop. I have replaced the adapter twice so far with the same results. Everyone I have talked to is completely stumped as to what could be causing this. Oil pressure according to the in dash guage is 30 psi at idle and around 40 psi when it breaks. A friend of mine is a mechanic and is going to borrow the shops live guage to confirm this, although i would think the filter would split before breaking the adapter. Here is the picture of both broken adapters.
LOL fist one was on truck when got it and second one was just "snugged" to approximately 10 ft lbs bringing an actual torque wrench out tonight when put new one on to make sure.
6 & 8 Second Club
Are you absolutely sure they are sitting flush.
That is definitely a weird deal you got going on there.
Worse comes to worse you may have to get a billet style??
lol well I am not really an engine builder but the local machine shop is givin em to us for 3 bucks a pop, I should just pony up the cash to throw my iron block LS1 together but school starts tuesday which means no more extra money for fun
Well just took it out for a test run in the field and the adapter seems to be holding up quite nicely after a few redline wheel spinning passes. Oh and put it on with out the gasket, not sure if thats what solved the problem but seems to work out, thanks for the help 89.
Oh, so there was no factory gasket there, that is interesting the engine was supposedly rebuilt by the PO before the truck was wrecked, I guess that gasket is semi proof, thanks for the info!!
