N20 question
N20 question
i was thinking bout putting nitrous on the 2000 ws6 m6. What is the safest shot for a stock bottom end i got cam, headers, aftermarket intake, stage 3 clutch. I dont wanna blow the motor i heard u can run a 100 shot all day on a ls1 no problem is that true?
so far for me yes...make sure the tune is right. and that you pull timming. plus put a little colder plug in. A fuel pump up grade is good safety. plus A/F ratio. and hang on it is a good kick in the pants...you will want more for sure.
Guest
Posts: n/a
Depending on how much power you are making right now the first thing I'd look into is upgrading the fuel pump. Other than that I'd at least pair a window switch and FPSS -( Fuel Pressure Safety Switch )-. Those items are two major safety items that will help in the pursuit of a safe system. I'd sugget getting a WET system.
-Chris
-Chris
how big of fuel pump?
-Chris
-Chris
Guest
Posts: n/a
