Sponsored by: DashLynx
880 to h3 fogs?
Old 09-27-2009, 08:30 PM
silverbandit0996's Avatar
Default 880 to h3 fogs?
how would i go about wiring up a set of Hella 2500 fog lights with a HID H3's in place of my factory fogs? splice wires? new connector?
Old 09-27-2009, 08:44 PM
bluetransam95lt1's Avatar
You may be able to find like a 880 to H3 adapter.or even but the correct connections to make your own plug and play connection so you dont have to cut any wires.....or just splice the wires onto the new H3 connector. Im sure its just a + and - hookup.
Old 09-27-2009, 09:43 PM
so if i were to make an adapter i would need an 880 female and an H3 male to connect right?
Old 09-27-2009, 09:55 PM
yes i believe so.
Old 09-27-2009, 10:31 PM
The Guz's Avatar
You can get an 880 relay harness. It will connect to an H3 HID bulb with no problem.
Old 09-27-2009, 10:46 PM
which would be cheaper? cleaner?
Old 09-28-2009, 12:10 AM
The Guz's Avatar
The harness is about $15. Its cleaner and the ballasts will get power from your battery while still using your factory swith as the trigger.
Old 09-28-2009, 12:23 AM
for two? is so is there a sponsor that sells them?
Old 09-28-2009, 11:38 PM
The Guz's Avatar
You only need one harness. It will connect to both ballasts. Search for 3bspec. I got my harness from him.
Quick Reply: 880 to h3 fogs?
