Drag Racing Tech
View Poll Results: faceplated t-56 or stall and trans-braked th350
faceplated t-56
64.29%
th350 with stall and brake.
35.71%
Voters: 14. You may not vote on this poll
faceplated t-56 or th350
Old 09-28-2009, 07:44 AM
ss2000's Avatar
LS1Tech 20 Year Member
Default faceplated t-56 or th350
I have my car ripped apart and I'm thinking about switching to a stalled, trans - braked th350 or having my t-56 faceplated. I hardly drive it on the street and I'm not concerned with street manners. What benefits from either set up. If I keep the manual, it will get a much better clutch also.
Old 09-28-2009, 08:34 AM
Camaro396's Avatar
Can't out shift an auto trans, and you won't get more consistant than a trans with a brake on it. I use a TH350 setup with a 8" 5200 converter, and love it.
Old 09-28-2009, 08:43 AM
SPEEDYws6's Avatar
Sticks are faster. True story.
Old 09-28-2009, 11:52 AM
ndfrsd6's Avatar
i've had both and my th400 crushed my times from my facepalted 6spd ....true story
Old 09-28-2009, 12:14 PM
Magnet's Avatar
an auto may be faster, and more consistent, but theres something manly about rowing gears.. I say be different and get the faceplated trans... everyone and their brother has an auto
Old 09-28-2009, 12:43 PM
Mikey 97Z M6's Avatar
What he ^^ said.
I know autos are generally faster and more consistent. I guess it depends what you're doing with the car. If you're professionally bracket racing the car, then it would make sense to go with an auto for consistency. But if you're just a weekend warrior that goes to the track for fun, I'd say stick with the T56. Personally, I enjoy dropping the clutch at the line and rowing the gears. IMO, that's "driving" the car, not just "steering" the car.
My .02.
Mike
Old 09-28-2009, 01:24 PM
SPEEDYws6's Avatar
Well I guess you know what that means? Do I need to say it?
Old 09-28-2009, 01:34 PM
turbo'd stang's Avatar
I've had both in a Mustang. For a NA, high reving motor, there nothing more fun than hitting gears. If you are trying to win races though, an auto is your better choice.
FYI, my car SLOWED down with the auto.
Old 09-28-2009, 08:26 PM
Camaro396's Avatar
I think you're confused on how a brake'd auto works. You're trans-brake locks first and reverse, allowing you to rev the car to your selected RPM, or up to whatever your two-step is set at, and when you release the button, it releases the fluid and takes off with a "drop of the clutch" effect. Also, with a trans-brake valve body, they are a reverse pattern manual valve body, meaning they will not shift themselves. You have to shift them, and can do so at your desired RPM. It's still "driving" the car, you just don't have to **** around with pressing a clutch in. I've driven plenty of T56 cars, and they are fun, but my first ride with my MRVB Auto with a 5200 converter, I was hooked. Nothing like clicking through a couple gears and not worrying about dropping RPM between shifts.
Old 09-28-2009, 08:27 PM
Camaro396's Avatar
Your turbo car slowed down with an Auto?
Old 09-28-2009, 08:31 PM
Magnet's Avatar
I have no problem with auto's... they are far superior in every way when it comes to drag racing... but when its a toy, you can't beat a 6speed.. if nothing else it adds a degree of difficulty that allows you to be occupied longer with a particular setup, bc you have to strive for that perfect run. Where with an auto a "perfect run" is much more attainable and repeatable..
Old 09-28-2009, 08:43 PM
SWeiser31's Avatar
The problem with the T-56 for drag racing is the first gear ratio. 2.66 really sucks for launching the car. With nearly any other manual trans, the car will be quicker than any auto with all things being equal. It is very possible to shift a manual trans as fast as an auto. You just need the right trans and lots of practice. Auto's are easier to be consistent and take much less maintenance to run, but in my opinion are not nearly as fun to drive. That's what it's all about to me, having fun. I plan on putting a Jerico in my car before too long. That 3 something low gear will really help.
Old 09-28-2009, 10:18 PM
waltsfastz's Avatar
Amen, I was die hard 6 speed until I took a pass inm y buddies th350 on a foot brake even. No worry about missed gears, left like hell, and at the end of the day cheaper to build and maintain. I went home that nite and took the 6 sped out of mine and put it up for sale.
Now if it was a decient streetable car maybey but not for what I do with it
Old 09-28-2009, 10:22 PM
LOL,,,, I wasn't confused in the slightest and I was plenty familiar with how a t-brake works. Pushing a gated shifter on a auto (t-brake or not) IMO still isn't "driving" a car no matter how you try to pretty-it-up. That "******* around with pressing in the clutch" is what makes it "driving" and not "steering" the car. That's just my opinion though.
Mike
Old 09-29-2009, 12:00 AM
MelScrilla's Avatar
if you plan on racing alot go for the auto. It seems like the T56 is prone to break no matter how you build them.
Old 09-29-2009, 01:31 PM
SPEEDYws6's Avatar
Anything will break... But I have put my t56 though plenty of abuse and the only failure it ever saw was a cracked blocker ring on 3rd gear. $150 for a blocker ring kit and it was good as new.
Old 09-29-2009, 01:35 PM
01Z28Camaro's Avatar
First time to track with new suspension with my 6 speed I got a best of 10.4 at 128 mph. Going back today, it's holding boost better, would like to see 9.99 with a 9 on the slip.
Old 09-30-2009, 01:06 AM
DADDY&GIRL93TA's Avatar
There is a prefect place to race stick shift with the umtr.http://www.umtrdragrace.com/. Some of the best racing i have seen in 25 years
