Suspension adjustment for mild wheelhop?
I just got my 28-11.5-15 Hoosier Quick Time Pro's mounted and on the car. Took it out for a test drive and everything felt fine, but I went back and looked at the rubber marks and it looks like I have some slight wheelhop. Unfortunately I can't get away with much street suspension testing. I have QA1 rear shocks, stock springs, and lower control arm relocation brackets with them in the bottom hole; do I need to stiffen up my rear shocks just a little bit? Any help is greatly appreciated. Thanks
Didn't feel anything, but could see it wasn't planting the tires squarely by the rubber marks on the road. I'm kind of concerned about ANY wheelhop; worried it may be magnified at the track with the nitrous.
How much air in the tires and what are the shock settings?
Either one will contribute to the problem....
LS1Tech Co-Founder
Are those tires like ET Streets, DOT slicks, not drag radials right?
I'd run the tires at 15 psi cold to start, and run the rear shocks at 7/7, more on the stiff side. I'd start from there.
They are bias ply tires, and they were at 15psi cold. The rear QA1's are set at 4, maybe that's my problem. When I had the 27's on the car everything seemed fine, this just showed up when I threw the 28's on the car.
