wheel and tire question
Old 09-30-2009, 08:02 AM
98 z28 mullins's Avatar
Default wheel and tire question
will a 15x10 with a 5.50 backspacing and a 325 50 15 mt et street radial fit on a 98 z28
Old 09-30-2009, 08:07 AM
i know someone on here has to know
Old 09-30-2009, 08:53 AM
Tommyv8's Avatar
Geez Quickdraw McGraw, give people more than 5 minutes at 8 in the morning.
Not nearly enough backspacing, 7.50" is optimal for a 10" wide wheel. And I know guys have run tires that wide back there, but there may be some massaging of the wheelwells neccessary. I tried to put a 315 tire on my car and it wouldn't fit.
Old 09-30-2009, 10:23 AM
Discount Tire's Avatar
Tommy is right on, 7.5" back spacing is ideal (50mm offset). If you have trouble finding exactly that keep it within these ranges (45-54mm offset) to minimize rubbing.
Old 09-30-2009, 02:59 PM
tals7's Avatar
Smile
i fit 325 mt dr,s with 7.5 backspace on my ta.ther are some pics in my albums.with 5.5 backspace and stock width rear they might stic out to far.
Old 09-30-2009, 03:35 PM
do you have any rubbing issues
Old 09-30-2009, 03:45 PM
tals7's Avatar
Smile
not sure if this question is for me but no rubbing issues.
Old 09-30-2009, 04:03 PM
ok is that with the 325 dr's and the 15x10
Old 09-30-2009, 04:34 PM
tals7's Avatar
yes 325dr on billet specialites 15/10 f-body wheels 7.5 back space.
Old 09-30-2009, 08:16 PM
ok thanks for the info
Old 09-30-2009, 11:30 PM
Camaro396's Avatar
I have 325s on 15x10 7.5 backspace wheels and they rub bad. I need my fenders rolled big time.
Old 10-01-2009, 07:22 AM
it could be that camaro are different but if that is your car camaro 396 in your aviatar it could be where you are raising the front ones
Old 10-01-2009, 09:01 AM
Camaro396's Avatar
It's just that the 28" tall tire (325) rubs on the over hand of the upper portion of the wheel well when ever the car squats, or hits a bump. It sits lower in the back than factory ride height though. Other than that, they tuck pretty good.
Old 10-01-2009, 10:34 AM
oh ok
