Drag Racing Tech
MEZIERE electric 35GPM waterpump STREETABLE...???
Old 09-30-2009, 02:59 PM
nemss1's Avatar
Question MEZIERE electric 35GPM waterpump STREETABLE...???
think i would have cooling issues with a 35gpm racepump on the streets?
seeing that the street version has a pulley and is 55gpm
Old 09-30-2009, 03:04 PM
tee-boy's Avatar
should work if wired into some type of thermostat. don't know where you'd get one.
Old 09-30-2009, 03:07 PM
nemss1's Avatar
ok thats basically what i needed to know. i noticed the race version didnt have a thermostat like the street version did
so the race version wouldnt cool down a car enough for the streets seeing it has no thermostat?
Old 09-30-2009, 03:09 PM
fknsmshn's Avatar
You mean a thermostatic switch or a thermostat to control coolant flow?
Old 09-30-2009, 03:21 PM
DanZ28's Avatar
Do you still have a serpentine belt system? If so dont you need the street vesion for the pulley? also, I don't think the race version has provisions for the heater hoses...
Old 09-30-2009, 03:27 PM
nemss1's Avatar
no power steering or ac/heater here so i was thinking of getting the race version
heres what i researched just now.....the HD race pump flows 42GPM and it does say strip/street, so i think i found what im looking for
the regular race version is only 35GPM
the street version, i seen no need for since i plan on running a belt around the crank and alt pulleys only. i dont need the heater hose provisions
Old 09-30-2009, 04:35 PM
tee-boy's Avatar
Default radio shack
The race pump can take the motor from 200 degrees down to 120 degrees in about 10 seconds (assuming the fans are in working order).
the thermostat would have to control turning the pump on and off at set temperatures. some electonics guru could probably figure out how to do that with parts from radio shack and a sending unit from auto zone in about 5 minutes.
Old 10-04-2009, 12:35 AM
TJ
TJ's Avatar
ive ran one on the street in my 3rd gen since 2004 without issue.
prolly burn up tomorrow...
LOL.
hottest the car has ever ran is 210 on a stock 4th gen gauge.
that was during 100 mile trip at 3500rpms.
it normally runs 180 or so, even in hot days in traffic.
car also has ls1 fans and radiator.
Old 10-04-2009, 07:52 AM
Race your car!
JL ws-6's Avatar
I've had a race 35 gpm on my car for over a year, did a little driving with it, and it was fine with no tstat. Stock dummy gauge read the same as it did with the stock pump.
A real gauge is needed to really know what the car is running at, the stock one in my car anyway, isn't much more then a dummy light.
Old 10-04-2009, 09:02 AM
veee8's Avatar
I used to run the 35gpm LT1 version on my LT4 for years with no issues at all on the street. 180* was the norm.
Old 01-19-2010, 05:26 PM
tee-boy's Avatar
Default fdfd
take your pick.
a switch would be the same as turning the pump on and off to control the flow.
a thermostat is a valve. How about a solenoid valve w/ a thermostatic switch controlling the valve.
Old 01-19-2010, 05:43 PM
daschra79's Avatar
For the guys that have ran it on the streets, How do you have it wired?Just to a switch? If so do you guys just turn it on and leave it on or do you switch it on and off when you see the temperature rising or falling?
Old 01-23-2010, 09:52 PM
kmracer's Avatar
most guys just leave it on. i wired one up for my buddy on an lt1, turns on with the ignition but the car also has a 180* t stat and stock fan temps of 213 and 227.
you could easily use a thermostatic fan switch, but where would you put the temp sender?in the block?
Old 01-23-2010, 10:00 PM
Magilla Gorilla's Avatar
im sure factory location in the head would be the best bet...
Old 01-24-2010, 07:33 AM
tee-boy's Avatar
Default dfdfdf
splice into coolant temp sensor on the driver's head.
Old 01-24-2010, 09:29 AM
InsaneAuto86's Avatar
Originally Posted by nemss1
the HD race pump flows 42GPM and it does say strip/street, so i think i found what im looking for ... the street version, i seen no need for since i plan on running a belt around the crank and alt pulleys only. i dont need the heater hose provisions
Got a link? You can PM me if needed. This sounds exactly what I am looking for with my build.
Old 01-24-2010, 11:29 AM
MrElectric03's Avatar
Its on the Meziere website, $498.14. The only thing I dont like is that it says its suitable on n/a engines up to 650hp, and if running forced induction, high compression, or high horsepower that the 55gpm street pump should be used. The entire point of running an EWP for me is that I have no accesories other than the alternator and I dont run a heater. I want a lightweight race pump without the pulley on the pump and the street pump is double the weight of the HD "street/strip" pump. My 11.5:1 isnt really high compression, and on nitrous I will make around 650 rwhp which means at the flywheel ill be well over 700hp.
Old 01-24-2010, 01:25 PM
kmracer's Avatar
you'll be fine.
Old 01-24-2010, 07:45 PM
daschra79's Avatar
Thanks, that what I was planning on doing but just wanted to make sure.
Old 01-29-2010, 11:33 AM
tomz28's Avatar
my buddy has one and it makes so much nosie, i hate it. is that the normal with all of them or is his screwed up?
Quick Reply: MEZIERE electric 35GPM waterpump STREETABLE...???
