Cam retaining plate part number
Old 10-03-2009, 04:11 PM
WS6FirebirdTA00's Avatar
Default Cam retaining plate part number
What is the part number for the cam retaining plate for the LS1?
Old 10-03-2009, 07:27 PM
KCS
Moderator
KCS's Avatar
There are two different plates now.
One has the bolt holes countersunk (newer style), and the other doesn't (older style). Not much of a variation, though. The part number I have is 12556437.
Old 10-03-2009, 09:39 PM
That is what I found.
Old 10-03-2009, 11:10 PM
massls1guy's Avatar
I believe the dealership only has the newer style now. Make sure you buy new bolts to go with it, your originals won't work.
Old 10-04-2009, 12:07 AM
Monte4ever's Avatar
Do you know the bolt Part number?
Old 10-04-2009, 07:58 AM
11561455 is what I found. Only one thread on the forum I have seen with these P/Ns
Old 10-04-2009, 01:20 PM
blkbird's Avatar
When i got mine from the dealer it came with the new bolts.
Old 10-04-2009, 02:25 PM
Well then I just wasted 20 bucks on bolts if that is the case lol
Old 10-04-2009, 02:50 PM
JonCR96Z's Avatar
Damn, did you tear everything up?
What rockers were you using again? I need to remember to stay away from those.
Old 10-04-2009, 03:54 PM
I had 3 lifters go bad, the roller started to go (stock). That was all. Cam actually looked OK but I am not taking my chances, so time to rebuild the top end.
Old 10-04-2009, 04:04 PM
JonCR96Z's Avatar
Oh, I meant lifters. So they were the stock ones.
Old 10-04-2009, 04:05 PM
Yep, gonna go with LS7s since I don't have the $$ right now for the Morels.
Old 10-04-2009, 07:39 PM
427's Avatar
Tighten the new retaining bolts to 12ft lbs, any higher and the plate may crack.
Kurt
Old 10-05-2009, 06:08 AM
Thanks, I was reading that in the other thread as well. Good info.
Old 10-05-2009, 09:56 AM
01ssreda4's Avatar
A steel plate will crack?
Old 10-05-2009, 10:32 AM
Anything can crack with improper torque. The bolt seat is tapered so it is much easier to crack.
Quick Reply: Cam retaining plate part number
