Western Members CA, AZ, NV, UT, CO, NM, HI
Possible Wheel Bearing Replacement?
Old 10-03-2009, 08:40 PM
93Z28rare's Avatar
Default Possible Wheel Bearing Replacement?
Hey everyone. Hope you can help me find out what the problem may be. The rear right "wheel" makes a loud squealing sound with a very hard, fast, and tight left turn. I also noticed as it was being dyno'ed for smog, that the wheel looked as if it was slightly wobbly, especially compared to the right. Am I right to think that it might be the wheel bearing? Thanks.
Old 10-03-2009, 10:20 PM
lowerthanyou00's Avatar
its common on these, throw an axle saver bearing in there so u dont havta buy an axle too
Old 10-05-2009, 12:51 AM
93Z28rare's Avatar
Sorry to ask, but what is an axle saving bearing?
Old 10-05-2009, 11:37 PM
its a replacement bearing that relocates where it rides on the axle where the axle normally gets torn up from the old bearing seizing.
Old 10-06-2009, 12:55 AM
93Z28rare's Avatar
Where can I get the part and what is the proper name? Also, where is a good place to get the actual axle bearing? Thanks everyone.
Old 10-06-2009, 10:04 AM
depends whether or not the axle is actually torn up, otherwise delco, napa, or even autozone carry decent bearing. autozone has the timken bearing axle saver. and ya thats what theyre referred to as.
Old 10-06-2009, 03:49 PM
93Z28rare's Avatar
Thank for everyone's help.
Old 10-07-2009, 01:53 AM
Smmokin01SS's Avatar
you might just have to replace the entire axle too, i have a bent axles the does the same things you say. so might have to look for a new rear
Old 10-07-2009, 10:11 AM
93Z28rare's Avatar
Are you serious? I hope not.
Quick Reply: Possible Wheel Bearing Replacement?
