which catch can with 2004 LS6 Valley Cover?
Old 10-05-2009, 09:48 AM
slayer_taunu's Avatar
Default which catch can with 2004 LS6 Valley Cover?
i'm planning on getting a 2004 LS6 Valley Cover (PN 12577927) for my 2001 LS1.
being that the RevXtreme catch can has a built in PCV, would this cause issues with the 2004 valley cover (which has the fixed orifice instead of the PCV)? and should i go with a Saikou Michi instead?
Old 10-06-2009, 12:10 AM
my concern is that it would be like running 2 PCVs and maybe it would cause some weird vacuum issue
Old 10-06-2009, 11:40 AM
TLewis4095's Avatar
You could run 5 PCV valves in line, and no issue as the valve only allows x-amount of vacuum in. The restriction is the fixed orffice, and it has no one-way check valve feature so gasses can flow both ways.
This thread should answer all your questions:https://ls1tech.com/forums/generatio...outing-ok.html
Old 10-10-2009, 03:47 PM
405HP_Z06's Avatar
Agree^^^ No issue with the RevX PCV valve.
Old 10-10-2009, 04:45 PM
vipvegas's Avatar
Didnt know if you know. On the 01 block you have to notch out a section of the block for the new valley cover so it doesnt hit.
Old 10-10-2009, 04:49 PM
MiniTransAm's Avatar
Vote here for the revXtreme. Both for the product AND the customer service!
Old 10-21-2009, 09:19 AM
ok, after much internal debate, i decided to order the 01-03 LS6 valley cover, and the RevXtreme can. i couldn't find any comparisons of the oil separators between the early/late ls6 designs... only that the late design has the fixed orifice pcv built in.
with the 04 cover, i'd be stuck with the fixed orifice, which i read can potentially cause vacuum issues if i do a H/C setup down the road. with the 01-03, i can use the PCV in the can, which will keep the clean appearance, and i can always add the external fixed orifice later if i feel so inclined.
Old 01-18-2010, 01:04 PM
just did my 1st oil change after the LS6 valley cover & catch can install.
although only 500 miles passed since the swap, the catch can was completely empty. not even a single drop came out. While doing the swap, there was a significant amount of oil pooled behind the PCV valve on the stock hose, so i was expecting at least SOMETHING in the can.
Looks like the LS6 Valley cover really works. can't wait to see if oil consumption really improves this year.
Old 01-19-2010, 09:02 AM
bandit-00's Avatar
Which part number did you end up using for the Ls6 valley?
Old 01-20-2010, 09:22 AM
the pre-04 valley cover is 12568002. you also need the plug for the drivers side valve cover: 12568011
