Drag Racing Tech
C5, H & C, Stock CID, 10.77 @ 125 all motor
Old 12-03-2003, 02:13 PM
7 Second Club
Phil99vette's Avatar
Default C5, H & C, Stock CID, 10.77 @ 125 all motor
Took a trip down to MIR this past weekend..... The weather wasn't as good as the Import vs domestic race but it was decent. I am going to calculate the DA here shortly. When we arrived down @ MIR it wasn't very busy being the last race of the season so I went through tech and let my car cool down.....
Weight: 3320 on MIR scales
Temp: 47
Dew: 42
Pressure 29.92 and dropping
DA = ~-560
First pass tires were @ 15psi
60' 1.61 (launched soft to check the track conditions and bogged bad)
Tagged the revlimiter on the 1/2 shift
shifted 6500
11.00 @ 124.9
Second pass tires were @ 16psi
60' 1.52
Bogged again out of the hole, launched @ 7k, shifted @ 6500
10.84 @ 124.9
Third pass tires were @ 18psi
60' 1.57
clean pass really bogged off the line
10.94 @ 124.6
Third pass tires were @ 14psi
Let the car cool down so engine temps weren't 200, the car felt good came out of the hole decent but bogged again
1.51 60'
6.8x 1/8
10.77 @ 125.8
Fourth pass tires were @ 15psi
1.58 60'
10.91 @ 125.4
Fifth pass tires were @ 17psi tried slightly different shift points
1.57 60'
10.94 @ 124.9
Phillip
Old 12-03-2003, 02:27 PM
Motorboater
SilverGhost's Avatar
Nice, that's flyin. congrats on the new best!
Old 12-03-2003, 02:45 PM
bspz28's Avatar
Very nice .. How did it feel to launch at 7000 rpm's. congrads on your new best .
Old 12-03-2003, 03:00 PM
7 Second Club
Thx, It really didnt launch hard due to the rear and tranny ratios. We're working on it....
Phillip
Old 12-03-2003, 03:24 PM
CHRISPY's Avatar
great job!
congrats!
Old 12-03-2003, 04:47 PM
jfm
jfm's Avatar
Congrats Phil,nice times,good to see when things pull together and run well.
Old 12-03-2003, 04:53 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Congrats!!!!
Old 12-03-2003, 05:49 PM
7 Second Club
Thanks guys, I am still working on a few things,
1) going from 3.90s to 4.10 gears
2) Fast Intake
3) Big TB
4) More tuning
5) Maybe modifying the cylinder heads more bowl work and decreasing the runner size.
than comes da juice
Old 12-03-2003, 05:57 PM
STEALTH C5's Avatar
Nice times. What octane do you run with the 12.2 to 1 compression?
Old 12-03-2003, 05:59 PM
7 Second Club
93 octane, the cam grind has soo much overlap/no advance it bleeds off alot of compression. Makes it seem like a 11.0:1 with a small 224 cam. I could have done the same thing with 11.1:1 CR and advance the cam 4-6 degrees like the cams come normally.
Phillip
Old 12-03-2003, 06:13 PM
LSX Mechanic
Damian's Avatar
Nice work Phillip, imagine what that bad boy would do in -1500 DA
Josh
Old 12-03-2003, 06:27 PM
Terry Burger's Avatar
Nice times! I assume A4?
Old 12-03-2003, 06:35 PM
7 Second Club
I am waiting on the DA to move to -1500 maybe even -2000. My corvette is a 6 speed and I shift hard and fast.
Phillip
Old 12-03-2003, 07:10 PM
Hardtop's Avatar
Awsome Phillip, that Vette is flying.
Bruce
Old 12-03-2003, 07:58 PM
7 Second Club
We're planning on hitting capitol in a week or so when the temps drop alittle. Hopefully we can pick up .1 in the 60' and the temps will give me another .1-.15.
Phillip
Old 12-04-2003, 08:05 AM
EVIL's Avatar
Phillip
bad azz phil!
i need to find a light vette to put my setup in!
Old 12-04-2003, 09:29 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Very nice times!
Coach
Old 12-04-2003, 08:44 PM
GrannySShifting's Avatar
Good times Phil!
Id like to see where that motor is making 400 lb ft or more at from what rpm to what rpm.
Have you tried different shift points? Doesnt seem like that cam should peak all that high
~Jeff from FBC
Old 12-05-2003, 08:21 AM
7 Second Club
I only have a few passes on the setup. We're shifting at 6500. I dont know if it makes 400rwtq. At least on my dyno it doesn't make 400rwtq. I don't dyno race.
Phillip
Old 12-05-2003, 08:37 AM
its got to somewhere 404 lbft is about 100% VE and most of the good heads/cam cars are hittin that mark somewhere. Id be surprised if the car was not making that much between 4300-4800
You had me wondering when you have 7500 rpm of fun in yoru sig, that cam shoudl peka about 6400
