Gm Tremec 3550 To Ls1?
Old 10-07-2009, 12:49 AM
white84z28's Avatar
Default Gm Tremec 3550 To Ls1?
Hey Guys,
I recently started a Ls1 Swap into my 84 H.O. Z28. The car already had a low mileage tremec 3550 swap done when i bought it. Again this is a Gm Version of the tremec 3550, so it already has the correct 26 spline 1 1/8 input shaft.
Due to a recent driveshaft failure i was forced to upgrade to a lakewood blowproof bellhousing with mounting points for the stock 3rd gen hydraulics. This bellhousing will fin 153 and 168 tooth flywheels, so thats not a problem.
Im concerned that the depth of the flywheel and clutch will affect clutch release. From what i have gathered from searches is that ls1 using autos require a spacer so that the flexplate is where it should be. I am not sure if this is a factor on a standard setup.
So is what i am asking is with out trashing my bellhousing and stock hydraulics, can i use a ls2 flywheel and ls7 clutch/pilot bearing with my application or will i run into issues with clutch release.
Any support is greatly appreciated.
Old 10-07-2009, 08:36 AM
85MikeTPI's Avatar
If you search for TKO / LSx combos, you'll have the same issues.. You can't really mix the OEM LSx clutch/FW setups with older fork clutch systems. You'll need to make the choice on the clutch engagement setup, then adapt from there..
Old 10-07-2009, 08:43 PM
white84z28's Avatar
what about switching over to a hydraulic throwout bearing and shimming it up to spec? will this allow me to use a t56 style clutch?
Old 10-08-2009, 08:31 PM
85MikeTPI's Avatar
It might be possible.. I'd check with McLeod and see if they've setup a combo like that before with their sleeved hyd TOB. You'll probably have to test fit the setup and take measurements to get the correct TOB and spacers.
Old 10-09-2009, 04:13 PM
jmd
jmd's Avatar
Check into the extended pilot bearing; the LS_ crank is further forward (except for early production 6.0 cranks IIRC.) That would potentially take care of the input shaft length issue.
The external slave / relocated pivot fork / TO brg. situation will work out a few diff. ways. Possibly a taller TO brg. Possibly an adjustable ballstud (not sure if the Lakewood is threaded for the stock hyd. thirdgen ballstud)
There are a number of a/m hyd. TO brg assy's that are meant to slip onto the bearing retainer sleeve too.
Old 10-09-2009, 07:49 PM
white84z28's Avatar
the lakewood bellhousing is only threaded for an adjutable ball stud, but the tko requires an adapter roughly a half inch thick to mount to stock t5 bellhousings to change the pattern from the 17* tilt to straight up. My Lakewood has added mounting points for muncie/borg warner trans with the straight up pattern. I think i may be able to adjust the stud out possibly the .4" that the flange is set back. Im still concerned with the depth of my bellhousing.
After doing some research i have stumbled upon something thats i wish i saw earlier. My bellhousing (part #15020) shows a depth of 6.45". When I looked up the lakewood bellhousing for Muncie/Richmond/Borg Warner to Ls1 with mechanical linkage(part # 15005), the depth is showing 6.45" as well. Im thinking with this new found info, i can toss my adapter, use the trans in its intended straight up location on the bellhousing, I "should" be able to use my stock hydraulics with some adjustments on my pivot ball and use a standard lsx style clutch.
What do you guys think?
Old 10-10-2009, 11:52 AM
jmd
jmd's Avatar
I assumed (and you confirmed) that you had the 84-92 application dual pattern bell, which is great. I did not know that it was threaded for their adjustable ballstud at the 84-92 location; that's great for your app.
Your trans + rotation plate + T5 bell = works w/ SBC. Which means that removal of the adapter would put your input into the crank the right amount for LS_. But that's if your TKO is the straight-up T5/Muncie pattern that's on your Lakewood bell. (I don't know the TKOs well.)
Starting to sound good.
Old 10-10-2009, 01:58 PM
white84z28's Avatar
Thats the one thing i will have to double check, Mines not a tko, its an early tremec 3550, so im hoping it has the muncie and not the square ford pattern. Last time i looked at it i thought it was the muncie pattern, but its currently on the back of my sbc in the car. I may still run the Mcleod extended pilot bearing just to be on the safe side. Once i get the motor built i can pull my old powerplant and start test fitting everything.
Worse comes to worse, i can sell my hydraulics and bellhousing/adapter on thirdgen.org and either retrofit a t56 master/slave setup or give keislers universal kit with an aftermarket Hydraulic TOB a shot.
Hopefully all of this will work out, id hate to try to sell my trans and pick up a used t56 thats probably trashed... at least thats what i see after people open em up. Another reason is weight, since my 3550 is lighter.
Quick Reply: Gm Tremec 3550 To Ls1?
