Duralast and Moog tie rods the same?
Old 10-07-2009, 08:39 AM
rollinna65's Avatar
Default Duralast and Moog tie rods the same?
I've read before that some Moog products are sold under other brands at a much cheaper price. Apparently they're all made by Federal Mogul or something like that. Anyway, I'm looking to replace my tie rod ends and I'd much rather pay $17.99 vs $50.99.
What do you think?
http://www.autozone.com/autozone/cat...questid=731019
http://shop.advanceautoparts.com/web...S_715235642___
Old 10-07-2009, 08:49 AM
deelong4002's Avatar
Usually the duralast stuff is made in china, and MOOG should be american made. What is most likely is the Duralast Stuff, is rebuilt MOOG stuff
Old 10-07-2009, 08:55 AM
SantaCruz163's Avatar
I bought brand new Moog tierod ends on Amazon for ~$35/ea.
Just do a search for the Moog part number for our cars.
Old 10-07-2009, 10:22 AM
rollinna65's Avatar
Thanks for the info, for that much its not worth taking the risk.
Old 10-07-2009, 11:09 AM
1995blacktattop's Avatar
yeah i'd go with the moog stuff. I paid a little bit higher prices for my stuff but since i also got an alignment and the total was only $300 ($320 w/ a $20 off coupon for any work over $200) i figure it's like i paid the higher prices but got the parts installed for almost nothing. IIRC had i gone to advance and bought inner and outer TRE's it would have been $235 before tax. so it's like i only paid $60 for the instal and alignment.
Old 10-11-2009, 08:11 PM
JimMueller's Avatar
LS1Tech 20 Year Member
I always use the MOOG ProblemSolver series if available... IIRC it's their heavier duty line.
Old 10-11-2009, 09:19 PM
FasTimeSS's Avatar
don't cheap out on suspension parts definally use moog it will last you longer
Old 10-12-2009, 07:32 PM
Wesmanw02's Avatar
I wouldn't use anything besides MOOG or OEM parts for suspension. Just about everything else is garbage.
Old 10-12-2009, 10:57 PM
tbird31's Avatar
I've got the BAER bump steer tie rod ends and LOVE them.
Old 10-13-2009, 10:05 AM
TRANS-DAD's Avatar
You also got a beautiful car!!!!!
I'm not up on BAER tie rods but they make quality parts
so like was stated before just don't go cheap on suspension parts!!!
Old 10-13-2009, 10:12 AM
Big_Bird_WS6's Avatar
anyone tried the poly tie rod things for energy suspension?
Old 10-13-2009, 10:19 AM
http://www.energysuspension.com/sear...l=60&year=2001
^^^ that is link to all energy parts.
and this is what i am talking about
what do you all think of this?
Old 10-13-2009, 06:27 PM
leadfoot4's Avatar
The "poly tie rod things" are simply replacement boots for the rubber boots that tend to crack and tear. I've used the ES boots and they are cool, but not really necessary.
Old 10-13-2009, 06:31 PM
leadfoot4's Avatar
The Baer tire rod ends are a combination of heim ends and an adjustable "pedestal mount" that is attached to the spindle in place of the outer tie rod end. The "pedestal" allows you to adjust the mounting height of the heim up and down, so you can get the tie rod to more closely follow the arc of the lower control arm. This, in turn, allows you to minimize bump steer, especially on lowered cars.
Old 10-13-2009, 08:35 PM
well a new moog is like say 45 each. and i can get a set of the poly parts for like 20 for a set. that is alot cheaper. and the poly will last probly the life of your car
Old 10-13-2009, 09:01 PM
Wesmanw02's Avatar
So we know the boots will last (being poly), but what about the actual tie rod ends themselves??
Moog joints meet or exceed OEM in terms of quality, and still use poly boots to seal out dirt.
Old 10-14-2009, 05:21 AM
Major_Lee_Slow's Avatar
The moog part is the entire tie-rod. The Energy supension poly boot is, well, just the boot. Do you need to replace the tie rod because it's worn or are you replacing it because the boots torn?
Old 10-14-2009, 06:21 AM
leadfoot4's Avatar
Good point. It appears that there is a little confusion on "BigBird's" part...
Old 10-14-2009, 07:57 AM
Nightrydass's Avatar
I have MOOG inner/outer tie rods. I can tell you this, bump steer has been GREATLY reduced. Not elimiated, but GREATLY reduced.
Old 10-14-2009, 08:12 AM
i am sorry my moog that i bought last year are great. i was just posing an option for the OP. then i was asking about the poly parts as a replace ment.
i dont need tie rods. just trying to throw outher options out there then just replacing the whole piece.
now if my moog boot tears i will probly run the poly part.
Quick Reply: Duralast and Moog tie rods the same?
