Drag Racing Tech
402-418ci trap speeds
Old 10-11-2009, 05:33 PM
6.0monsta's Avatar
Default 402-418ci trap speeds
Hi all. I was looking to compare trap speeds from 400ci setups. Specifically in the 402-418ci range.
I feel like my car doesn't dyno as well as some stroker setups but wanted to compare my mph to others.
2006 GTO
416ci
500whp
3600 raceweight
Best trap speed is 126
DA was +1500
Looking for car, weight, displacement, whp, and trap, DA. Thanks to all that contribute.
Old 10-11-2009, 05:43 PM
daniel6718's Avatar
i got a buddy with one that traps 106 on motor in the 1/8...weighs about 3300
Old 10-11-2009, 05:44 PM
Moderator
JayplaySS's Avatar
126 in a 3600LB GTO sounds right on to me @ 500rwhp. I've seen 500rwhp F-bodies do that and worse not to mention a few 500rwhp C5's and C6's under 130 as well.
Just my observation, I know it doesn't add technical value to your thread.
Old 10-11-2009, 05:45 PM
6.0monsta's Avatar
Looking for a little more info.
Old 10-11-2009, 07:23 PM
ls2 bait's Avatar
car is 3706 w/o me. im between 140-145.
t56 w 4.11 gear
28x10 et drag...works for the n2o but not so great for the motor. going to make some drag radial passes very soon
416ci 520-530whp depending on the weather
traps are 127-129 on motor, havent hit 130 on the slicks.
dont know the da...my best pass was in the middle of july in florida.
Old 10-11-2009, 07:28 PM
daniel6718's Avatar
402 with l92 heads stock and stock l76 intake...low 240's cam...tun th350...4000 stall
Old 10-11-2009, 07:58 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Friend has a 10.x:1 408 cid with ported L92 heads, 490rwhp on motor thru auto. Car trapped 128 mph. I'm guessing 3500 raceweight and small converter.
Old 10-12-2009, 09:37 AM
6.0monsta's Avatar
Keep em coming.
Old 10-12-2009, 10:03 AM
ATVracr's Avatar
99' Formula
396 (iron block with 3.9 crank)
Never dynoed
141mph
3200lbs.
+2000 DA roughly
Old 10-12-2009, 12:16 PM
6.0monsta's Avatar
Guess I should specify that I'm looking for NA trap speeds.
Old 10-12-2009, 12:34 PM
ATVracr's Avatar
If you were refering to my post that is what it runs N/A.
Old 10-12-2009, 12:49 PM
6.0monsta's Avatar
Gawd dawm! Not even gonna ask how because my car will never trap that on spray much less NA!
Old 10-12-2009, 03:27 PM
6.0monsta's Avatar
Solid roller? I know a guy with a vette with 510whp and a raceweight of 3150ish and he only traps 130 with a stock LS2.
Old 10-12-2009, 07:19 PM
ATVracr's Avatar
Yes ... Great heads and intake and a solid roller.
We only made like 4 motor passes all year I think in good air with a motor converter and the right gears it would go low 9's @ 145 ish
Old 10-14-2009, 08:59 PM
JaSSon's Avatar
346 n/a, traped 128 once the rest are 127's.
Old 10-15-2009, 01:50 PM
ndfrsd6's Avatar
402 here 3000 race weight and i trap 130 plus N/A
Old 10-15-2009, 02:09 PM
CARTEK Racing
WS6TransAm01's Avatar
Depending on the race weight and the motor you should be well above the 130 mark.
I traped 132 with a 346 and 3300lbs race weight...
A well build 402 should put down at least 50hp more than my 346, that should trap 136 or 137 given all other variables remain the same...
Old 10-15-2009, 02:33 PM
6.0monsta's Avatar
My race weight is 3500+
It's a GTO with a mild cam and auto car. I think 127 will be about my maximum.
Car is completely streetable. Driven to and from the track. Bone stock suspension. No trailer queen drag style tricks. Just a mild 416 setup in a GTO.
Old 10-15-2009, 03:30 PM
jmm98LS1's Avatar
My race weight is 3900lbs and with ~500rwhp n/a I trap 123-124 and then 134-135 on a 175rwhp shot.
Quick Reply: 402-418ci trap speeds
