Possible to change gears in tranny? th400
Old 10-12-2009, 09:53 PM
rtpassini's Avatar
Default Possible to change gears in tranny? th400
should I have any gears changed or switched up while its being rebuilt?
Right now I just dont have the money to redo the rearend right now. its a 2.73 with FULL posi.
I figure if i can switch up the gears somehow, i can offset the high rear end to give me better low end.
this is in a 1980 T/A by the way. Im new to domestic transmissions. so thats why it may be like im asking stupid questions.
Old 10-13-2009, 08:25 AM
fast01's Avatar
Yes, you can change the gear ratio in the tranny, but it requires a new planetary gear set and it's not cheap. The TH400's factory ratio is 2.48/1.48. You can get a 2.75/1.57 for greater torque multiplication, but again it's not cheap. We're talking more than half the cost of the tranny itself, in the $700-$800 range and should you eventually upgrade your rear gears and add more power, you may end up with traction problems. If you want to get the most out of your 2.73's, make sure you run the proper stall and run the shortest overall tire height you can.
Old 10-13-2009, 09:59 AM
Gingervitis Addict
slow67's Avatar
And the 2.75 gear set is only good to about 800 hp. Don't get the TCI gearset either.
Old 10-13-2009, 11:10 AM
darkhorsebob's Avatar
Arrow
That was the old TCI 2.75 gear set. The new 2.75 set has six pinions and a steel billet stand which contains the the six pinion gears. The sun gear is no longer welded, it is splined to a sun gear sleeve. This new setup is as good as any gear set made!
Bob
Old 10-13-2009, 03:18 PM
Arrow
TCI also has a 2.97 1st gear set with a 1.57 2nd gear.
Old 10-14-2009, 04:52 PM
chris718's Avatar
Sounds like the company has copied JKilgores means of retaing the sun gear.Reversed helix angles on a common sun gear does not work.When the sun gear "screws" the ring gear in first gear with no thrust surface it eats itself up in short order. When they are not connected this is ok.Ill post a photo later of the right way to do it.
Old 10-14-2009, 07:27 PM
chris718's Avatar
This is the right way to make a sun gear for a 1.57 second gear 400 which gives a 2.75 first gear
Old 10-14-2009, 07:29 PM
chris718's Avatar
Default photo
photo of gear
Attached Thumbnails Possible to change gears in tranny? th400-new-stuff-chris-oct-2009-003.jpg
Quick Reply: Possible to change gears in tranny? th400
