Belt Slip What have you done to fix it and why?
I have a F1A on my nova with an 8rib pulley setup. Its a Divorced drive. I was just wondering what you did to cure you slipping Issues. I am tying some new things to help out I will let you know my results. In the mean time post up what you guys are doing to solve your problems. Here are some solutions that I have found.
Short of going to a cog drive set up. I know the Vortech guys in the Renegade drag racing class don't like the coated pulleys cause they eat up belts...
http://www.reichardracing.com
http://www.carbiniteracing.com/
I will post up pics of my "Modified Pulleys" in a little bit.
8 sec potential, 12 sec slip
Aster made this setup that is very nice looking: https://ls1tech.com/forums/forced-in...m-bracket.html
Last time I checked, he could put together other kits for cheaper than an SDCE setup. Not sure if he's still able to resource all the parts anymore, last I talked to him was about a year ago, but it'd probably be worth checkin into.
I put one of the SDCEs on my car & have no slippage anymore. And we just installed one of Asters on my neighbors car (402 with a D1) & it looks like it should work fine, haven't tested it yet tho....
