Need help quick with a trans leak
new harness or just the o-ring. i forget what it looked like on the other side. i know the claws of the connector that hold it to the case make a leak free area by keeping pressure on it. i paid 85 bucks from GM for the harness that i had to put in for a temporary trans i had to use during winter last year. i had a similar leak from the same spot.
either way the pan has to be dropped since thats how you get the connector out form the trans case
