PCM after nitrous backfire.
Old 10-20-2009, 02:52 PM
BLKND_02's Avatar
Default PCM after nitrous backfire.
2002 Camaro SS
LS1 5.7
Tremec T-56 M6.
Bolt ons.
Bullets.
Suspension.
Track only car.
VP ms109 fuel.
Zex LSX Wet Nitrous System: 125 jet.
Zex TPS WOT Controller, Window Switch: On-2800/Off-6300.
Zex Power Racer Spark Plugs.
Nitrous tune by Cunningham Motorsports.
Dyno w/125 shot, rwhp 477, rwtq 520.
Tested on short street runs, all was great.
First run at track with new set up/tune:
1) Missed a shift (3rd to 4th) resulting in very small backfire.
2) Got off the gas right after backfire.
3) While going though the traps the RPMs
shot way up as if the throttle was stuck,
did not hit rev limiter.
4) Shut it down and coasted back to pits.
5) No physical damage to intake/MAF found.
6) Started engine, idle/rpms shot up to apprx. 3200-4200
while sputtering and backfiring, shut it down.
7) No related DTCs found, but could not do a full drive cycle.
Any input would be great.
Old 10-20-2009, 08:28 PM
Moderator
jimmyblue's Avatar
If you didn't pull the manifold, there's a good chance
you missed a crack or hole in places you can't see.
Or just blew the MAP sensor out of its hole.
Old 10-20-2009, 09:59 PM
JDMC5's Avatar
yeah I agree, you could have one gynormous vacuum leak. Did you check the TB blade?
