First time to the track in the Z06
I had a great time, and Im really happy with the numbers. this thing has more in it, just need some more practice. only did 4 runs that day. my best 60ft was a 2.0X, but lost traction in 2nd gear as you can see in the vid I also did a 2.1, but also lost traction on 2nd gear and ended up running 12.55. In this run (My best and last run), I tried to let off a little on 2nd gear and shifted a little slower, and it worked and ended up running 12.54@118 with a 2.2X 60ft. I was really improving, and I think i will be able to get a 12.3 slip if I managed to get another 2.0X 60ft
http://www.youtube.com/watch?v=Es3fpvJvOPY
Track Elevation = 4900ft
No doubt a 7100 DA will hurt performance but even more so traction is slowing you. You have 118 mph even at that elevation. That's a mid 11 second car. I have an 11.35 @ 118.35 mph time slip that I ran with my 98 Camaro. It was an automatic with a stall which is going to be faster than a manual but still shows what that mph can produce.
