Weird 3-4 shift at the strip, now it's ticking
Hey guys, decided to go to the drag strip for the first time in a while. I'm back home now with a few crappy timeslips and a ticking Camaro.
Car is a stock internal 98 Z28 with bolt-ons, suspension mods, and a Spec 3 clutch.
First run, going for the 3-4 shift at the top of the track, I pull the shifter to 4th and release the clutch. The whole car shudders like crazy, feels like wheel hop. The kind of thing you'd be a little less surprised to feel on a 1-2 shift. I can't figure out what's going on....
Second run, I'm a little nervous, but the 3-4 shift is normal.
Third run, the shudder situation I had on the first run occurs again. I immediatey clutch-in to coast as soon as this happens. The 'check gages' light catches my eye, and I notice 0 RPM, engine isn't running. As I'm coasting, I turn the key and it just cranks....tries to start...but doesn't. Turn the key off, crank and give it a little gas...and it starts up. I pull it over and hear it ticking at idle. Oil PSI is ok. Shut it off, check oil, check for leaks, everything looks good. I'm assuming/hoping it's a lifter. Drove it the hour-long ride home as gently as I could, ticking the whole way.
Anyone experience anything like this? Any ideas? I've got no clue what was happening on that 3-4 shift and no idea what's wrong with the car now.
Yep... check the pushrods. Its an easy job. Use something as a stethoscope to see which head its coming from. You could do this by putting your ear up to a wrench of something, while pressing the wrench on the valve cover. Next, take your pushrods out, and see if any are bent. If you have trouble telling, roll them on a flat surface... this should tell you if they are bent. Next replace bent pushrod, and see if it fixes the problem. If it still ticks, you probably have a lifter issue.
The stock pushrods are pretty weak. I have bent a couple one time when I over revved the engine for a split second.
Just pulled them, 3 bent pushrods.
Heads/cam are next, so I didn't want to bother upgrading anything on the current setup. I'm hoping I can just swap in some new pushrods and we'll be good to go, no other damage.
because he is about to upgrade to new H/C and will probably need different length PRs, no need wasting $120 when he could get CHEAP stock PRs. Id give him mine if he was close.
On a side note.....something must be wrong with your hand position when you shift. Change it so your palm is on the left side of the shifter when you shift from 1-2 and 3-4. That will keep you from trying to pull it down and towards you inadvertently.
Yeah, I'm looking to pick up a set of used stock PR's for now. It would be H/C time if I didn't have my house up for sale at the moment. If it sells, I want to have the car driveable to get it to the new place. Too much of a pain to try to move a non-running car.
I'm still amazed at the possibility that I pulled a 3-2 shift. I've had this car for years, been to the track many many times, and never had an incident.
Yeah... a missed gear
Good idea to move the hand placement. Although to shift 1-2 I would think you would do it normally to make sure you do bring it down and towards you. I bet the 1-2 isn't as common of a problem as a 3-4 though, which are the shifts I have missed a few times.
