oil pan help...
Old 10-22-2009, 01:24 AM
mark.deady's Avatar
Default oil pan help...
hello everyone. i have a oil leak from my pan unkown why but i think that the gasket is junk but i also think that i may have cracked the pan when i tryed to torque down the pan. i am looking for a cheep replacement... i also have installed a set of solid motor mounts. so i have a small amount more clearance. all options welcome. also i have searched and red over the lsx oil pans thread. i was looking at the moroso 20140 pan thanks for looking and have a great night...
mark
Old 10-22-2009, 11:08 AM
01ssreda4's Avatar
K member has to be dropped about 8 inches to snake the pan out.
Old 10-22-2009, 12:41 PM
mark.deady's Avatar
i know how to get the pan out i am just looking for a cheep replacement for the stocker... as i think that it has a crack in the pan.... the main thing that i was looking for was if the moroso 20140 oil pan will fit with the stock k member thanks for the help...
mark
Old 10-22-2009, 01:49 PM
'00zbird's Avatar
Just get another stocker from a salvage yard. Try the gasket first though, it's a quick cheap fix. It's possible that you tore the gasket torquing it down to hard. Did it on my 3rd gen once.
Old 10-22-2009, 02:27 PM
mark.deady's Avatar
just a little back ground on the car for ya as well... the gut that i got the car from tore it apart about 8 months ago... he replaced the lifters, and timing chain. he put it all back together but forgot the oil pan bolts. they wee hand tight and that is it... plus he could not get the 2 that are just under the k member installed so he just left them out... on top of all this the dip stick is loose... he cross threaded the bolt that holds in to the block... still working on getting it out...
Old 11-01-2009, 09:46 AM
mark.deady's Avatar
still looking to see if the moroso pan will work with my stock k member ta... thanks mark
Old 11-02-2009, 05:33 PM
01ssreda4's Avatar
What a dipshit.........I hate ghetto shadetree mechanics.
Old 12-08-2009, 07:31 AM
mark.deady's Avatar
any one know if the moroso 20140 pan will work with all the stock stuff... also i am running a set of solid motor mounts.. thanks for all the help...
