Drag Racing Tech
Anyone running a aftermarket/relocated coolant overflow?
Old 10-22-2009, 05:23 PM
taws6m6's Avatar
Default Anyone running a aftermarket/relocated coolant overflow?
If so what and/or where did you buy or relocate the tank to? I ask this in this section cause I know drag guys relocate a lot of stuff. Mainly interested in the relocation part of the question.Thanks
Old 10-22-2009, 07:10 PM
Race your car!
JL ws-6's Avatar
I bought a summit overflow tank, and relocated it into the spare tire well... ran a line from the front of the car to the back The coolant doesn't re-circulate from there, so anytime anything gets in it I have to add it back to the radiator (because I put the feed on the top and the bottom that has the ball valve runs out the bottom of the car, so I can drain it) but I don't find that a big hassle.
I run the radiator down about 1/2 an inch from the normal full line anyway, so there isn't much that ever gets back there, probably about an ounce or 2 after an entire day of racing, unless I fill the radiator up 100%, in that case a good bit will get back there (because it has to expand and go somewhere)
I should also mention, I run strait water... not sure of coolant would make a difference or not.
Old 10-22-2009, 07:19 PM
DopeFedZ's Avatar
Same here I have mine relocated to the spare tire well and it also doesn't recirculate. I can post up some pics when i get home if you want.
Old 10-22-2009, 07:20 PM
Race your car!
JL ws-6's Avatar
Yeah, I just don't have a picture of it handy.
Pretty simple to do, only hard part was stretching the hose over the nipple on the radiator LOL. I could have done it the right way with an adapter, but I was too lazy to go back out to the parts store again.
Old 10-22-2009, 08:59 PM
Rogue86's Avatar
I use the summit plastic one. Its mounted at a 35º angle (from horizontal) on the side of the radiator support under the passenger frame rail. Not the greatest angle for storing a lot of fluid, but it doesn't really puke that much out.
I'll try to get a photo.
Old 10-22-2009, 09:06 PM
silverz28camaro's Avatar
Water cools beter then a 50/50 mix, but the problem is that it freezes below 32 degrees and it does not lubricate the water pump seal as well.
I thought about doing something different with my coolant overflow, but there really isn't any benefit from messing with it, the stock tank is plastic, so why would you add weight by running extra line, and an aftermarket aluminum tank?
Keep the stocker, unless there is a weight advantage.
Old 10-22-2009, 09:14 PM
Rogue86's Avatar
Mine is relocated to clean up the engine bay, and it does get rid of a few lbs. I run 100% water with Wix Cool additive. But the block and radiator gets drained for the winter.
Old 10-22-2009, 09:28 PM
Pics of your setup? I'm always looking to shed a pound or two if possible
Old 10-23-2009, 05:33 AM
Race your car!
JL ws-6's Avatar
I do cheat and run a little water wetter.... but I don't think it does that much to be honest, I didn't see any change when I put it in.
I put the overflow in the back of the car for safety, if you puke the head gaskets and pressureize the cooling system you could push all the water out and into the overflow.... if it's in front of the tires, that means when it overflows it's going on the tires, not good.
That's why I put it in the back, that plus the hose and summit bottle vs the stock overflow tank, I guarintee it weigh's a good bit less.
Old 10-23-2009, 09:27 AM
DopeFedZ's Avatar
Old 10-23-2009, 10:10 AM
Race your car!
JL ws-6's Avatar
You can see the small plastic summit bottle I went with here. Not as nice as the setup that carlos did..... but it works, and was probably a good bit cheaper
Old 10-25-2009, 01:29 PM
Rogue86's Avatar
Pictures of my setup:
Old 10-26-2009, 09:00 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Noting for the future.
Old 10-26-2009, 05:16 PM
spaulding's Avatar
ive got a small one from autozone or sumwhere like that,thats mounted to the outside pass side frame rail under where the stock one wnet,cant see its there but does its job and is in a good spot to drain/keep an eye on it,edit i think i even used stock mounting holes that were there for sumthing or i put rivnuts in i cant remember
Old 10-27-2009, 08:25 AM
tee-boy's Avatar
for those running an overflow...what radiator/radiator cap are you guys running?
Stock radiator has a screw on type cap. don't think there is any valving on the stock cap.
Old 10-27-2009, 12:08 PM
Rogue86's Avatar
Northern 28 x 19. 16 lb or something cap from orielly's.
Old 10-27-2009, 12:50 PM
Race your car!
JL ws-6's Avatar
I still have a stock on on my radiator.
When the little radiator goes in it will get a 20 lb cap.
Old 03-16-2010, 01:13 PM
OlMastaScrilla's Avatar
Sorry kind of bringing this back from the dead, but I have a question for DOPEFEDZ or anyone who knows.. In the first pic what size/style an fitting is that on your stock radiatior? Thanks for the help.
Old 03-19-2010, 01:32 AM
cbrrmike's Avatar
sorry in advance for this stupid question, but i have the pictured catch can, which nipple do i run my overflow line to, and what is the best option to do with the other nipple....
thanks
mike
Old 03-19-2010, 02:05 AM
kmracer's Avatar
if its a street car, consider that it'll sound like you have gerbals in your trunk.
we did it to my buddys. its kinda funny.
Quick Reply: Anyone running a aftermarket/relocated coolant overflow?
