whats a good compound to get rid of swirls
im looking to really detail my camaro before i put it away for the winter,
i was wondering what are some good products that will get rid of the lite swirls BY HAND!!
im basically looking to get the car looking perfect before i put it away for a couple months.
is 3m rubbing compund any good or stay away??
whats a good wax?? on a red camaro
i know its gonna take while but im willing to do it
i dont trust anyone else buffing my car and i dont trust myself yet
any info would help
thanks
any info would help
thanks
I just did my entire car with Meguiars products. Before you ask...I used Zaino (exclusively) for 14 years. Still the best stuff I've ever used.
With that said, I had mostly fine (some you could feel) swirls. Not wanting to spend a fortune on new Zaino products, I gave Scratch X 2.0 a try, based on it's low cost and positive review. All I can say is ...WOW! The stuff worked incredibly well. It takes a bit a work (constant rubbing with moderate pressure) but the swirls and light scratches vanished. You do a small area at a time, rubbing in a hard, to medium, to light progression. Then you wipe it off before it dries with a good microfiber towel. I then used Meguiars Deep Crystal polish, followed by NXT wax/sealer. I had to have a few panels repainted, so I took care of the rest of the car so my painter could make sure to get a good color match. He was so impressed with what he saw, he couldn't believe the paint was 14 years old (mostly, I attribute this to Zaino though). But, I always had light swirls.
Give the Scratch X 2.0 a try. Don't bother with the Swirl X, which is less aggressive. I tried that too, and didn't like the product. it's too thick, dries too fast, and couldn't do much on even the lightest swirls.
One more thing - clay the car first. It takes very little time, and will remove fine abrasive particles embedded in the paint. The last thing you want to do is use the Scratch X and grind in more swirls. It's probably the biggest mistake people make. All it takes is a few particles to make more swirls.
1 Post
3Ms stuff is the only thing I use and Meguiars gold wax. But the 3M products youll need a buffer to use it..they have a 3 step process..and 3 different pads..You can get it at an Orileys or some parts stores like that..but the compounds to a walkin is really $$$ but its the best..
How bad are your swirl marks. I would stay away from filling glaze because it fills the swirls and not remove them completly. Depending on your swirl makes will depend on what process you should do. You most likly wont be able to remove swirls by hand but you can fill them by hand which is not the right fix in my opinon.
you have to stare at the car for while with spot lights,and then you might see them
but i look at the car every day and i can notice them, i might just leave em, but im just getting the car ready for winter storage so i want it to be spotless before i put it away for 6 months.
Smoke Em - I'll summarize.
For about $6, try the Swirl X 2.0
If it doesn't work, you can call me whatever you feel is appropriate. I gave you my personal experience with the stuff...nothing else I can offer.
I would hit it up w/ a PC or if you want to get done faster use a Dewalt 849. But use white foam pad and Meguairs 205 if that doesnt work use a orange pad. That should work perfect then hit it up again w/ a gray pad then a good sealer of your choice. Be patient and the results will be worth a million bucks! I got both polishers and a **** load of pads. If you are proud of your ride you will probably invest in something like this for sure.
3M rubbing compound with a variable speed polisher/sander with a foam pad then come back with a mequires glaze and finish it off with a good quality wax , i use IBIZ wax (really good stuff, best wax ever).
