Any reason not to remove this plug/bolt & connect to the oil galley?
Passenger side of block, front lower end, right behind the A/C bracket mounting hole area there is a plug/bolt that leads to the oil galley. I want to use the access point for an oil temp gauge. Wanted to clarify that the bolt doesn't have any purpose other than a simple plug. Didn't know if it's restricting cross-flow or something. Please confirm. Thank-you
