I-shaft
Save your money. If it is anything like mine, the shaft will still be tight but not greased up enough. Buy a tube of synthetic chassis grease and just pack it in as much as you can, make a mess if you have to, then clean up the excess. It will fix it good.
....I was hoping noone would ask me this...You'll see why as I explain it... The steering shaft has to be completely removed, which is not hard. Under the dash just pull back the boot and undo the nut. Do not confuse the nut end with the bolt head end, if you try to remove the bolt head you will just bust you knuckles. The jack up the nose of the car and remove the driver's side wheel. Look towards the steering rack till you see the white boot going up into the car. Raise the boot up off the rack and undo the bolt on that end. I think you can then pull the shaft out, either on the inside of the car or the outside...I dont remember... Once you get it out you will see the slip joint that has the splines....heres the erotic part.... as you try to move the joint up and down it should have a sticky action....That means its needs...lube.....Lube up splines on the shaft and try to get some grease on the back end opening of shaft by universal joint... work the lube in by moving the shaft up and down.... Really make a mess of it, just glob it on..... When you are done, just clean up the excess except what is on the is on the splines. Reinstall the shaft....
