Opinions on Center Console
I want to "Upgrade" to the CTS center console. (at least just the higher level arm rest) I've been seeing some deals on Ebay for Tan and Black. Now, I have a Tan interior with the Black Dash and Door Panels.
Opinions on which one I should go for. Tan, or Black. I don't think it would look bad changing to black because of the offsets of the rest of the interior.
-Chris
-Chris
I got pretty tired of the tan in mine so I switched it out with a black center. I didn't use the regular CTS because I like the lower arm rest but you can get the idea of what it would look like. The only thing I haven't done yet is remove the rear section of black carpet and replace it with my original tan pieces. Once that is done I think it will look even better. I put a picture of a V with a tan console right below so you can compare.
YES! This is exactly what I was thinking. It looks very good; Exactly what I thought. My tan/Redline CTSV looks just like the 2nd picture. I figure if I'm replacing the center, I might as well get the raised arm rest. I think it would be more confortable for me.
Thank you very much! 2003RC51
So, I assume that the CTS Automatic Center Console would convert over to a CTSV Standard console just fine?
It looks like the same base console. If the automatic insert comes out it looks like it would have the exact same opening as the manual.
I just bought a black standard CTS autotragic console to put in my V, that has puky tan interior. I plan to install this tomorrow and I'll post up some pics. I'm wanting to convert my whole interior to black at some point. The sides of the console I got are tan, so if anyone wants to trade out I'd be glad to. Otherwise I may just pull the tan carpet off and wrap with black carpet that I use on my car audio installs.
I bought my console from ebay from the LKQ corporation. That's the second thing I bought from them and both pieces have been in good shape. Not mint by any means, but still in good enough shape to use.
Since we're on this interior subject, if anyone comes across any black parts, such as carpet, that I may need for this swap, PLEASE pm me! I can't get anyone to talk about this on the "other"forum at all, and I've even PM'd a reputable member 2 weeks ago and he hasn't returned the pm.
I'm really considering doing this now...it really does look great. It would just suck to re-do all the fab work I did to get my LM-1 and Microedge nitrous controller to fit in a new console though!
The Harris Speed Works Microedge+ is a progressive 2 stage controller with a window switch, WOT switch, lean shutdown, all sorts of delays, it really is the best nitrous controller on the market. I don't have pics of my setup but I'll try and get some taken soon. There really wasn't much "fab" work, other then cutting the inside of the console to fit wires and get the LM1 to fit flush in there so it's all hidden unless you put up the arm rest.
