42lb duty cycle of 115% at only 0.5bar - possible?
I made few pulls after installing TC78 to my 383ci. It's non-intercooled as of now, at 0.5 bar. HPT showed that at 6000rpm my 42lb injectors are working at 115%. AFR was 10.8. Is this possible? What power I should be making then?? I thought I have no more than 500HP (crank), but apparently injectors shouldn't be maxed out then??
Well I would suggest a Boost Referenced Fuel preasure regulator. It helps take your injectors further. But considering you have a 383 and I am assuming you will turn up the boost at some point get the 60lb injectors aftermarket rails and a BR FPR. When I got my procharger I sold my 42lb injectors right away and got 60's
