Intercooler ambient air flow TRANS AM
Old 11-06-2009, 03:01 PM
1SLwLS1's Avatar
Default Intercooler ambient air flow TRANS AM
What do most people do to get good flow through the cooler, radiator, and condenser on trans ams? Remove the license plate cover or what?
I see how camaros do it, but I don't see pics of what A/A ICs Trans Ams do.
Anyone got pics?
Whats the largest size people have fit in their T/A? I would much rather invest in a huge A/A IC without doing meth to keep IATs down.
Old 11-06-2009, 04:15 PM
NoGo's Avatar
No picks, but I removed the license plate cover and cut through the bumper support and foam. I then welded in some plating to better route the air to the intercooler - forming a tapered duct.
I then built a custom frame with some mesh to cover up the hole and keep bugs out.
It seems to work okay.
I am running an 18 x 24 (if I remember correctly) core that sits immediately in front of the radiator.
Old 11-06-2009, 04:22 PM
1SLwLS1's Avatar
Thanks, how thick is you IC? I would think that this setup would be much more beneficial for keeping everything cool, as air can come straight in through the IC, then the vertical radiator, and the vertical condenser.
Old 11-06-2009, 04:58 PM
The Fugitive's Avatar
check out my pix you can see some of what goes into it or imagine.
Old 11-06-2009, 09:57 PM
XtremeDime's Avatar
I cut the bumper support and slid the IC into it. My IC is 3" thick. Im also reusing the foam w/ the foglights being retained.
Old 11-06-2009, 10:57 PM
1SLwLS1's Avatar
I am guessing I will just cut that hole out. Would you think that a hole that big would be enough to cool the IC, radiator and condenser in Houston heat, stop and go, DD? I mean I am not shooting for killer power, maybe 500+
Old 11-06-2009, 11:28 PM
Restricted User
98Z28CobraKiller's Avatar
the air bridge/dam is how the radiator and condenser get fresh air. You must run that or you will have trouble keeping it cool on the move.
Old 11-07-2009, 06:59 PM
Restricted User
1BAD_LS1's Avatar
look at my sig picture... cheap ebay intercooler and works great! I have no air dam or any of that stuff and i have no overheating issues....
Old 11-08-2009, 12:27 AM
1SLwLS1's Avatar
Do you have a vertical radiator and condenser?
Old 11-08-2009, 01:11 AM
XtremeDime's Avatar
I believe he is running no a/c with a vertical radiator. Im thinking about running a vertical condenser and rad though...
Old 11-08-2009, 03:27 PM
1SLwLS1's Avatar
Im thinking I am going to have to do that as well. I will still try and make use of the air damn as well.
Quick Reply: Intercooler ambient air flow TRANS AM
