New 1/4 mile best today
Made the trip to Bowling Green today, eas a bit of a cluster f*ck all day, got stuck in traffc for over an hour so ended up getting there a couple hours late, plus it was super crowded, plus the weather wasn t that great, 75* degrees and a falling barometer.
First pass something happened with the tree and I got no time, 2nd pass was a 9.21 @ 145, third pass was blowing the tires off the line and getting back on it around 100' out, not sure what happened to that malibu in the other lane but I heard a pop and he was heading right at me for a second. I was on the 275 radials again, honestly they work well sometimes but when they dont work they really suck lol. The cam is really running out of steam up top, but a 9.20 wasnt bad for the weather. If I catch a cool day it should get in the 9.0s and with the larger diameter slicks is should get a little closer to 150mph. Not bad for a 347, D1SC and Y-pipe exhaust I guess..
http://videos.streetfire.net/video/BG-110709_717889.htm
8's are around the corner. You know how to make a fast car. You want it faster, but like I said today 9 out of 10 guys with your setup would be happy/lucky to run 9.70's or so.
I dont want it faster, hell I dont really want it at all lol - especially after a day like today. Under 1000ft DA, a cam change and 50-100lbs out of it would get in the 8s. I really wish there was some closer 1/4 mile tracks around here..
Any good pics/video you can e-mail me
nice Kp!!! I see that time vs mph and see how bad my weak 60s hurt. what was your 60 and 1/8 et/mph? I got those same tires and chattered the hell out of them....I need to go up on air pressure...I tried 16psi cause YOU did Mine did better at 18 cold.
you missed an excellent chance to run at SDR. the buick gns were there friday and saturday ....awesome track prep.....95% all drag tired cars and quick staging lanes...87 degree track temps. they ran friday from 10 AM to 11 PM
Like he said earlier the cam is probably done up top and he had a slight stutter up top. He didn't have time to fix the tune as they were closing the lanes down.
If I had the money the car wouldn't be in Tennessee anymore lol, but I don't. It's sad, but I keep hoping no one comes up with the money so you push it into the 8's or something else happens that you just love it and wanna keep it.
Honestly if I retarded the cam and put some taller tires on it it would run closer to 150 at BG but the ET wouldnt change any, My old car I could let off and coast at 8-900' and still run a 9.0x @ 100mph, thats what shows you how important the first 330' is ET-wise. Granted big MPH shows you are making the power but weak ETs means you just arent using it well, but making 4000lbs 60 foot well certainly isnt easy
I can run 16psi no problem with these, 18 or so I just blow them off, pressure is pretty touchy though and all cars are different. I have all rod ends in the rear suspension and that cuts down on the radial chatter, if you have any rubber/poly bushings it will chatter bad. I'll probably go back to slicks, way more consistent, much better on marginal tracks and easier on parts.
I wont sell it now, I'll keep it until spring at least, may as well enjoy the good weather..
nicely setup car as always KP.....maybe you need a class to race in? drag racing should be alot of fun.....it is for me anyways...course there is always those days when the oil downs won't stop or the staging lanes are always full....just a thought nothing serious
I can put the car on the bumper if I want to, not only does it kill the 60 foot but it also breaks things. Good for pictures though but the only picture I care about is the one of the ET clocks
That T-brake, two step, 5000 stall, 3350 lb raceweight and a good hook are the reasons that little D1SC/347 LS1 runs so hard. Nonetheless, a little cammed 347/D1SC engine can get it done when the rest of the set-up favors its power curve.
Nice job! Although haven't you been 8's already with the D1 in the other car, same set-up, or was that with the F1A on it, can't remember even though this all looks so familiar. I like to see such a simple combo outrun alot of these turbo cars that are on this forum. Just shows a properly set-up package will yield great results.
Couple questions for you.
Was this with race gas? How much timing were you running? Boost?
