4L65E/Vig 3200 installed!
Well, I finally drove my Z tonite after a month of it sitting broken in my garage. The new tranny feels real good and i swear the Vig is stalling around 3600 or so (looser than my BROKEN TCS 3400). Thanx to all the people who gave me info about swapping the L65 into a an F-body!
MiKe
MiKe
- Hardened input shaft
- Hardened output shaft
- stronger Lower/Reverse roller clutch
- 7 clutches in 3-4 clutch pack instead of 6
- Hi-energy clutches instead of stockers
- deeper pan (2 quarts extra i believe, i installed a B+M that holds 3 quarts extra just for max cooling anyway)
- 5-pinion planet gears instead of 4-pinion
- upgraded sun gear
- recalibrated valve body operation (im guessing it means better quality shifts)
- Brand new, not a rebuild
- 12-month warranty
- Obviously all parts are genuine GM and not some rip off (like the chinese-made 5-pinion planets that have a reputation for exploding)
- Im not positive but i believe it also has a larger intermediate servo.
built to go behind the 6.0L and the LS6.
- upgraded sun gear
- 12-month warranty
Overall good choice though. Let us know how it works.
well the crate had a sticker that said GM performance parts on it....but at the same time it had the truck tailhousing and shift linkage so i dunno? are the 2WD trannies set up with the correct tailhousing and stuff already? thanx for the info bad apple...
The fact that the crate said "GMPP" leads me to beleive you got the Holden/GMPP trans (a good thing). Two more questions:
1) Do you remember the part number? Truck: 24217285, Holden/GMPP: 24221888.
2) Is there a serial number sticker on top? Truck: 613KZD......... Holden/GMPP: 613HZD.........
Originally Posted by 11 Bravo
I read that the 4L65E is rated to 400hp. Better than the 4L60E, but dosent seem to be strong enough for most of us. Could be wrong, though.
Originally Posted by Trojan T/A
Are the gear ratios the same in this tranny; and its essentially just a stronger 4L60E from the factory? How would this tranny compare to something like Yank's 4L70?
i did get the GMPP one then because i know the part number was 24221888. also the tailhousing looked exactly like a 4L60 without the torque arm bolt holes. also im pretty sure there was an HZD on the sticker on top. do the holden applications use a longer shift lever or the same as the 4L60? mine had the longer one which had to be switched.
either way i guess its fairly conclusive i have the GMPP/Holden Tranny.
thanx for the help BAD APPLE.
Happy to help.
