Drag Racing Tech
Victor Jr.
Old 11-10-2009, 02:28 AM
00MaroonZ28's Avatar
Default Victor Jr.
Does anyone in here have experience running these on an LS1? I've got the mod's in my sig and FAST and I'm thinking of trying out the Victor Jr cause I'm focusing the car more for the strip. Will this make a better intake for drag then the FAST? Thanks.
Old 11-10-2009, 04:40 AM
Nimitz87's Avatar
nope no ones ever used it.
did you do a search? there is a ton of threads about the carb style intakes and the pros/cons to them.
you'll lose some power down low, power band will be moved up, and peak power will increase.
Chad
Old 11-10-2009, 03:26 PM
Yep. Did a search and only saw 2 threads that had very, very vague info on it. I understand that only a couple people are using it, but I haven't seen much info on it or the benefits vs cons. I do understand the powerband is moved up higher. I see a lot of the drag racers using it, but is that just for the forced induction aspect?
Old 11-10-2009, 03:33 PM
spoonraker's Avatar
I've seen a few people use carb style intakes without FI. They just stick an elbow on top of the intake and put an air filter on the end of that. I'm kind of curious too why somebody would choose to do that.
Old 11-10-2009, 04:12 PM
Nimitz87's Avatar
TONS of people are using this intake...make sure you set your settings to sort by relevancy, and put " " around the words you want to search.
here are a few results I found
https://ls1tech.com/forums/forced-in...rb-intake.html
https://ls1tech.com/forums/forced-in...ht=victor+gmpp
https://ls1tech.com/forums/forced-in...r-vs-gmpp.html
no, alot of nitrous guy's use it as well I plan on running one on my L92 headed 408 when the time comes, and the reason is there is no other intake really out there (the LSXR) that will flow enough for it.
hardest stuff is making it all fit.
Chad
Old 11-10-2009, 04:13 PM
Nimitz87's Avatar
the 90/90 was/is a bottle neck on larger motors the only way to feed them is with a sheet metal ($$$$) or the single plane jr/gmpp style intakes.
Chad
Old 11-10-2009, 05:51 PM
jmill96Z's Avatar
Nope, never used one
Old 11-10-2009, 06:15 PM
Nimitz87's Avatar
^^^ race car right? do you street drive it with no air filter?
Chad
Old 11-10-2009, 06:27 PM
jmill96Z's Avatar
I have a little 6" filter that goes on there for street duty. I'll see if I can find a pic of it. It fits perfectly.
Old 11-10-2009, 06:28 PM
Nimitz87's Avatar
oh WOW now that is something I want to see/do.
sorry OP for the slight hijack.
you have retained wipers yes?
Chad
Old 11-10-2009, 06:37 PM
jmill96Z's Avatar
The wipers are gone. I probably could have kept them if I would have wanted to.
I don't have any pics on the car, but here's a mock up picture.
Old 11-10-2009, 06:53 PM
Nimitz87's Avatar
nice! wonder why others haven't done that, at least I havn't seen it most run the elbows.
If I could retain the wipers and do that, that's awesome!
Chad
Old 11-10-2009, 07:05 PM
jmill96Z's Avatar
Haha. It was the $15 special at the local Autozone. People get into the mindset that if everyone isn't doing it, it must not work.
My second stage noids are the reason I cut as much away as I did. I got tired of cutting my hands up reaching back there all the time.
Old 11-10-2009, 08:48 PM
Nimitz87's Avatar
yeah I missed those the first time around...looks like I could make it fit very well.
and I hear you on the "monkey see monkey do" mentality.
Chad
Old 11-11-2009, 01:36 AM
Ok, thanks a lot guys. Awesome info.
The reason I was asking was because I'm going to a strictly drag setup with the spray. I had a 2 stage plate kit and with the fast was having issues. Basically, on the 150 shot I only was picking up 70 to the wheel and running rich. Dropped the pill settings from 38 to a 21 and still rich. I'm going with a bigger cam with the spray and I figured a 2 stage carbed plate with the victor jr would be a better set up for me since I'm gonna spin it to over 7k rpm's and have more even air flow to the engine cylinders. And I plan to put a bigger shot on there and don't want to lean the #7 cylinder and blow the engine.
Old 11-11-2009, 01:43 AM
Nimitz87's Avatar
MUCH better for that setup without a doubt.
sounds like something else is the problem w/ the 150 hit though.
Chad
Old 11-11-2009, 02:04 AM
358chevycamaro's Avatar
Chad
I agree here.
I have some similar intentions as yourself except instead of running a Victor Jr I am looking to go with a Super Victor to replace my Fast 90 setup.
Old 11-11-2009, 02:28 AM
Nimitz87's Avatar
Originally Posted by 358chevycamaro
I agree here.
the super vic is taller correct?
Chad
Old 11-11-2009, 03:40 AM
Yeah, it's taller. I'm not wanting to cut the cowl yet so I'm sticking with the victor jr. Super victor isn't very practical with the 4th gen fbody cars. Flows like crazy though.
Old 11-11-2009, 06:27 AM
They are if your windshield wiper cowl is non-existent.
