The infamous Turbo whistle...
Looking at videos and reading day in and day out on the world of turbos. I notice you have about 50/50 split of turbo cars that really have a distinct whistle to them and ones that dont.
What makes one make more noise than another? is it brand size or style? or mainly just exhaust setups?
What you might be hearing is the sound of the wastegates and blow of valves. Some people run external wastegates and some internal. Externals make quite a bit more noise.
My turbo car sounds like a heavy breathing hoover vacuum cleaner. You hear the turbos spool, then the external waste gates start playing their tune and then when I get out of the throttle, you hear the blow off valves actuating.
Funny
I'm putting the twins on soon, i'll keep this in mind.
This one is better!
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/W_Qul7MiImk&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/W_Qul7MiImk&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
This one is better!
I would like to know this as well. What gives the loudest whistle, lowest exhaust? Wastegate back into DP or vented? It seems returned back into the DP but I don't have a turbo setup yet so would rather hear from people with experience.
with the gate dump going into the down pipe you can hear the turbo better. with the open wastegate dump it sounds like a really bad high pressure exhaust leak( which is what a wastegate dump is actually) when you come into boost. I have tried it both ways and prefer the dump pipe recirculated, from inside the car you can hear the motor better
So can anyone really pinpoint the attribute that induces turbo whistle?
I know on my cummins truck it was a Silencer ring that I removed & it made a major difference.
Haha yes I've noticed a ton of threads being brought back up too. only thing I can figure is people have already tried most of the ideas that are being mentioned on here. as to the turbo whistle, I wonders that myself. just in my way home earlier I noticed an f150 like 4 cars up and his turbo was signing something fierce. I see it on alot of diesel guys. maybe one of our turbo gurus will chime in with even more info..
With the Garrett GT3782 (I think) that comes on 03-07 F series super duty trucks, the loud whistle comes from less blades on the exhaust wheel. 2003-early 2004 trucks has a 10 blade turbine wheel. Garrett put 13 blade wheels on the 2004-2007 6.0 and it got rid of the turbo whistle with straight exhaust
