Muffler is bad, replacement?
Old 11-15-2009, 05:09 PM
paulc87's Avatar
Default Muffler is bad, replacement?
I have a hooker catback and the muffler has developed a nasty rattle that really can't be fixed. Is there a direct replacement muffler I can get? I'm looking for a little louder but I'm not sure what kind of muffler can replace it
Thanks
Old 11-15-2009, 05:20 PM
vteckiller's Avatar
is it 3in tubing? because if it is this is the muffler that that catback came with.
http://www.holley.com/21518HKR.asp
or if its 2.5" tubing
http://www.holley.com/21508HKR.asp
Old 11-15-2009, 11:36 PM
Pontiacerator
RevGTO's Avatar
^ Not correct. This is the direct replacement for a Hooker catback w/ 3"/2.5". http://www.holley.com/21729HKR.asp
Old 11-16-2009, 09:57 AM
NC98Z's Avatar
Thanks
Damn mine too! I'm almost sure that its 3" into the muffler and 2 1/2" out to the exaust tips. I was actually thinking about taking mine off and running a single 3" in/out inline bullet type muffler single exaust. I've already got a DMH electric cutout under the passenger seat location that I open at the track. The mufflers that come on a Hooker catback are heavy as hell and I would have never thought they would come apart on the insides like they have done.
Old 11-16-2009, 03:07 PM
paulc87's Avatar
Darn, I'd rather spend the money to upgrade to true duals now
Old 11-16-2009, 09:07 PM
Pontiacerator
RevGTO's Avatar
The replacement is only about $100 and true duals will take you way beyond that. That being said, I run a single 3" in/out Hooker Maxflow. They run about $70 and are pretty light at 13 lbs.
Old 11-16-2009, 09:32 PM
MJs1FastSS's Avatar
+2^^^ take the advise from above
right on point ....
Old 11-17-2009, 02:06 PM
paulc87's Avatar
Is there another muffler that would be compatible as a "drop-in"?
Old 11-17-2009, 07:41 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
ANY of them.
Old 11-18-2009, 03:09 PM
paulc87's Avatar
Is it any louder than the regular hooker muffler? And how does it work considering there is 1 inlet/2 outlets on the regular muffler?
Old 11-18-2009, 09:44 PM
Pontiacerator
RevGTO's Avatar
Basically you just separate the Aerochamber from the over-the-axle pipe, weld or clamp the Maxflow on, and then have one 3" tailpipe fabbed with a turndown on the end.
Testing shows the Maxflow a little quieter at idle and part throttle and louder at WOT than the Aerochamber. I had an Aerochamber on my car for a while and I'd say the Maxflow sounds deeper and a little louder.
Do a search on "Maxflow" and you'll find threads with my install, the first guy to do it, db levels and other info.
Old 11-18-2009, 09:55 PM
Hugger's Avatar
I replaced the hooker muffler in my hooker catback with the F-body specific Dynomax muffler 3" in/Dual 2.5" out. It was almost a perfect fit. All I had to do was weld a 3 bolt flange to it and it fit perfect. I think I paid about $70 for it.
Josh
Old 11-20-2009, 08:38 PM
Z-28's Avatar
Default Borla FTW
I would Go with the Borla ProXS Mufflers they are the most powerfull. Makes more HP than the cutouts.
Old 11-20-2009, 10:56 PM
FasTimeSS's Avatar
Go true duals and do not go back you will not regret it.
