PRC CNC Cylinder Head Decking Video
Thought you guys might like watching the new PRC cnc cylinder head milling setup hard at work! This video shows a couple thou being taken off a LS6 cnc ported head!
This is just another perfect example of how we're always working to create the best possible product for our customers! The finish this setup leaves is absolutely awesome!
Enjoy!
http://www.precisionracecomponents.com/cncmilling.wmv
Enjoy!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
thanks thanks!!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
They use a Newan Contour BB http://www.newen.com/Pages/products/contour-bb.html It's a bad ****.
and it's spelled Newen!
It depends on how much you are taking off and how many passes. My father owns a machine shop and if your going to do a few passes and are going to be "shaving" the piece of equipment something as simple as oil can be used if you are going to do a lot of milling and are going to be getting out a lot of "meat" off the piece of equipment then you use coolant. (making of rims)
Alot of milling applications are ran dry, it also depends on materials, inserts yada yada. It's a common thing especially in interrupted cutting; face milling, end milling. Air is usually used in place of coolant. Wd40 will leave an awesome finish on aluminum, but you do not want to put oils into a cnc machine, as you will contaminate the coolant.
Enjoy!
Enjoy!
I wish more videos were posted by builders and machinists showing the behind the scenes techniques of how are engine are made and assembled. There's alot of things, at least for me, that I have no idea what it is or how its done and seeing videos of it that makes us understand what all these terms and processes actually mean is just awesome. I can watch them all day.
I've been dying to see sleeves getting pressed into a block.
