for 9 in center section
Old 11-22-2009, 08:29 AM
bumpin_records's Avatar
Default for 9 in center section
for the FI guys who are running ford 9in what center section are you running? Im wanting to know if its ok to run the stock center section or is it a must to run a aftermarket one due to the hp rate. Im hoping to run mid 8's in the car. I know its not the same as launching a nitrous car so there will not be as much shock on the rear end so is it ok to run a stock center section. thanks
Old 11-22-2009, 08:34 AM
Fireball's Avatar
I would run an aftermarket nodular...I run an aluminum on mine...
Old 11-22-2009, 08:36 AM
HUNTER02SS's Avatar
If you can afford the iron nodular, go that route, BUT, I did run a stock center section in my TT Camaro running low 9's @ 150+mpg and it weighed 3600lbs.
Old 11-22-2009, 09:51 AM
z28boysteve's Avatar
Just run a stock center, that's what I did!
This was in the 10s even on low 10 psi with 16 degrees timing 6,000 RPM launch (manual)
Go Nodular or Aluminum stock centers are weak!
Old 11-22-2009, 10:17 AM
Tally TransAm's Avatar
as much as it sucks thats an awesome carnage pic
Old 11-22-2009, 10:46 AM
HUNTER02SS's Avatar
With his PG and turbo setup, he will never launch @6000rpm off the t-brake, and will never shock the rearend like you do with the manual. You are comparing apples to orange's in his situation. A stock unit will work well if the budget is tight , especially if you just want to get the car running and get some test pass's in. BUT get a aftermarket case if you can afford to do so the first time.
Old 11-22-2009, 11:28 AM
yeah I know the manual is alot harder on things than an auto could ever be which is why Im forced to switch. Just wanted to show the worst case scenario. I just think a good Nod or Aluminum is a worthwhile investment because its alot easier to do it right the first time than to pay for the carnage later... You should see the dent in my floor!
Old 11-22-2009, 12:24 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,221 Likes on 778 Posts
LS1Tech 10 Year
I would avoid a stock Ford center section, I've known a few folks who have broken them in the high 10's and low 11's.
I have a 31 spline spool over here if you are interested.
Old 11-22-2009, 01:52 PM
patriotformula's Avatar
Heres another reason to not run a stock center... Looks almost identical to z28boys... This was when my 6 speed car was running high elevens... Can really ruin some **** when they do this... Pretty bad that my 390 rwhp 3400 pound car can do that to it, but its proof that stock centers are weak...
Old 11-22-2009, 08:22 PM
Zmg00camaross's Avatar
that some awesome pics i have a strange pro series case nodular iron, pretty sure i wont break with my goals of mid 10s.
Old 11-22-2009, 08:28 PM
ya... I stepped up to a Strange Nodular myself... not worried about it anymore
Old 11-22-2009, 11:41 PM
LOL I think im gonna get a strange center section, now i have to choose iron or aluminum. Those 2 pictures are scary. Thanks guys
Old 11-25-2009, 08:58 AM
Wicked94Z's Avatar
if you go aluminum make sure you're getting a through-bolt case like a moser or mark williams unit
Old 11-27-2009, 09:18 PM
Avengeance's Avatar
I decided on the nodular.
Old 11-28-2009, 12:52 AM
35th SS's Avatar
thats purdy sweeet.almost looks like mine on both cars.nodular on both.
Old 11-28-2009, 04:12 AM
I am a fan of the nodular. good choice, screw aluminum
Old 11-29-2009, 04:19 AM
Wicked94Z's Avatar
did you have to clearance the case ribbing at all to clear the TA mount? I have a nodular on order from moser right now
Old 11-29-2009, 03:08 PM
i had to grind on my case a little, i have a differnt 9 inch torque arm mount.
Old 02-24-2010, 11:09 AM
bww3588's Avatar
i have a stock ford NI pig with a moser housing and TQ arm bracket, and everything clears fine with no grinding.
Old 02-24-2010, 11:17 PM
02CamaroSSLE's Avatar
if i run a stock 9" center section housing will it gernade with my mods plus a tune, i should only be running mid 12's maybe a tad lower... i went to jegs and found the nodular center peice, does the yoke from the stocker bolt into that one? or do you have to buy another yoke?
Quick Reply: for 9 in center section
