Edelbrock Torque arms???
I am looking for a new torque arm for my 2000 Camaro SS. It is a 6 speed car and i just got thru destroying my 3rd torque arm so i am breaking down and buying a new one. It is an M6 car with heads and small cam, doesnt go to the track much anymore and when it does go back my new motor will be in. I am wanting something cheaper to make it driveable til i get my motor done and finish up the suspension. A buddy told me about the edelbrock ones, said he had one on his car, and it seemed really strong, but his car is stock. Anybody using one or know anything about them? I have looked at BMR and UMI also but they are both about 50-100 bux cheaper, just wanting to cut back as much as possible. Any suggestions?
Hello,
The UMI torque arm is a built out of larger and heavier wall tubing, the mounting plates are also machine from much thicker steel. This makes an excellent item for both the street and any track use. We offer both an adjustable and non-adjustable stock replacement... once you install it you won't have to worry about replacing it
www.umiperformance.com/2205
www.umiperformance.com/2206
If you have any questions regarding our items or our torque arm please ask and I will be glad to help.
Thank you!
Ryan
Thank you!
Ryan
LS1Tech Premium Sponsor
Just to give you another option to consider. Our torque arms are some of the strongest on the market with the results to back it up. Our full length arms are made from 1.25" x .120 wall dom steel with 1/4" mounting plates. We also offer two shorter versions for the more serious race car. also something else to consider if you go with a full length arm is a torque arm relocation bracket. It will give you some added adjustment for the torque arm and also save the transmission tail shaft from breaking. If you have any questions please give me a call.
http://www.bmrfabrication.com/F4.htm
LS1TECH Sponsor
I sell Edelbrock.... and UMI, and SLP. I'd recommend UMI for a number of reasons.
1. SLP is overpriced
2. Edelbrock is not as strong (but better than older versions).
3. UMI has both the adjustable *and* non-adjustable versions and the pricing is right.
4. I use UMI on my car.
Since we're talking options here, and I'm the only vendor who's chimed in who has more than one brand to offer.....
http://www.stranoparts.com/searchbym...=106&ModelID=7
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
most of the problems with edelbrock torque arms are with the adjustable ones. i picked up a non-adjustable one for $50 just because of the price. wanted to see the quality of it after hearing so many negatives. overall it's definitely better than stock. no way on earth i'm gonna break it at my power level.
if you can though, just save up and get a better one. nothing worse than having to buy parts twice.
Here's another one for the experts,
my car is lowered quite a bit with adjustable coil- overs, however I haven't experienced any adverse effects from the pinion angle probrably due to the power of the car or lack there of.
Can you explain what the benefits would be to go to an adjustable torque arm?
Do they hang down any lower than stock and which one tucks up the highest?
Would I need the relocation bracket?
Don't waste your money on the edelbroke stuff. I brought the adjustable TA and it snapped near the pinion adjuster. Check out the sponsors here BMR, UMI...I have parts from both and there great!
Our torque arm tucks up extremely well and does not reduce any ground clearance. Here is the item I would recommend for you- www.umiperformance.com/2205
If you have any questions please ask and I will be glad to help. Thank you,
Ryan
Thankyou for the insight, great pics... looks like a nice piece. Unfortunately, I'm not having a problem with wheelspin, It's usually a welcome thing!
When my 10 bolt takes a dump on me, or I figure out how to do an LS2 swap I'll be throwing whatever I can at it!
*Sorry for the thread hijack! ~DriftR
