Short Stick Shifter HELP
Old 11-24-2009, 07:25 AM
GoHardZ28's Avatar
Default Short Stick Shifter HELP
I just bought a UMI Short Stick and it turns out it hits my consule in 2nd and 4th gear. They said since I have a factory M6 that does not have a hurst shifter to buy the WS6 stort stick. Should I buy the WS6 or Lou's Short stick??
Old 11-24-2009, 08:15 AM
TRANS-DAD's Avatar
check tha for sale section for a factory hurst prob. can pick one up pretty cheap!
you'll have a shorter shift pattern & can use your UMI stick!
Old 11-24-2009, 05:26 PM
GoHardZ28's Avatar
That not a bad idea. Thanks... I will see what I can find.
Old 11-24-2009, 06:22 PM
Tbird232ci's Avatar
I ground down the console a bit, and slotted the shifter hole to pitch the handle forward a bit on my UMI stick so I don't hit the console as bad. I also left the bolts out in the console to it can move a bit.
Old 11-25-2009, 09:09 AM
teke184's Avatar
having the factory Hurst unit greatly shortens throws.
picked mine up for $50 years ago....worth every penny!!
other option is to go to a machine shop that has a big press...and have them put a 10-15 degree bend in the stick.
Quick Reply: Short Stick Shifter HELP
