UMI Performance Spherical Roto-Joint Released w/ 20% Off!
Hello Everyone,
This is the official release of our Roto-Joint spherical bushing. The Roto-Joint is now offered in many of our popular items with more being added in the future. Please click on the banner below for more information regarding the Roto-Joint. Thank you
Rear Lower Control Arms w/ Roto-Joint-
#2033- Non-Adjustable, Poly/Roto-Joint Combination
#2034- Non-Adjustable, Dual Roto-Joints
#2035- Double Adjustable w/ Roto-Joints
Panhard Bars w/ Roto-Joint-
#2036- Single Adjustable w/ Roto-Joint
#2037- On-Car Adjustable w/ Roto-Joint
#2038- Double Adjustable w/ Roto-Joint
Panhard bar/Control Arm Kits-
#203336- Non-Adj LCA w/ Single Adj Panhard bar
#203337- Non-Adj LCA w/ On car Adj Panhard bar
#203438- Non-Adj LCA w/ Double Adj Panhard bar
#203528- Double Adj LCA and Panhard bar
Replacement Ends- These ends will replaces 3/4"-16 Threaded Rod Ends
#0011- Right hand for lower control arms
#0011L- Left hand for lower control arms
#0017- Right hand for panhard bar
#0017L- Left hand for panhard bar
All Roto-Joint products are 20% off until Monday November 30th!
Click on the banner for more information regarding the Roto-Joint
Yes they are going to to hold up a lot longer than a rod end but give you a better ride quality and still allow you to have articulation and eliminate any binding issues. If you have any other questions feel free to ask and I will be more than glad to help.
http://www.umiperformance.com/catalo...v410a4s8rp5f52
Thanks
Brad
Yes we do offer them as a replacement option. Below is a link to show you what all we have to offer!
Thanks
Brad
whats exactly the pro/con's to the roto joint setup compared the the standard bearings? Will these eliminate the clunking when turning from my poly non-adj lca's??? Also which are better for drag racing?
Thanks
Thanks
The Roto-Joint features a delrin race inside. The delrin is a hard material with high wear resistance. As a car launches the delrin will not deflect like a rubber or polyurethane bushings, deflection can lead to wheel hop and traction issues. Inside the Roto-Joint the delrin bushing lines a machined spherical ball, this ball rotates in the delrin and allows the suspension to articulate correct, this is what prevents suspension bind. The Roto-Joint is an all around great solution with minimal con's. One of the only negatives it has is since the delrin does not deflect it will not be a as soft as a rubber bushing. However the delrin does absorb most shock and is very comparable to a polyurethane bushing for ride quality making it excellent for the street. These will also be fine for drag racing and work virtually like a solid bushing conrol arm.
As for your clunking, polyurethane bushings should cause any clunking. There are two things I can think of- 1. A loose bolt or 2. A bad bushing. Other than that poly bushings are street friendly.
Anything else let me know. Thank you!
Ryan
well, since roto-joints are supposed to lessen the amount of deflection like rod-ends, while still being very quiet for daily driving, why not just get these and enjoy the extra articulation that they would provide? not to mention they would be much easier to adjust while installed, as you wouldn't need to remove one end to adjust them. if i didn't already have poly/rod LCA's from them, that's the route i would go, personally.....
so the difference between 2034 and 2035 is one is adjustable and one is not, but both come with the new roto joints on both ends? and they are the same price for non-adjustable and double adjustable?
when would you recommend an offset bushing?
when you would recommend an adjustable version versus a non-adj? just wondering cause i do plan to upgrade to larger rearend at some point.
as a point of reference, my car's mods are listed in my sig.
thanks
tony
thanks
tony
thanks
tony
thanks
tony
Thanks for the interest in UMI Performance! Yes the difference is between the two like shown on our site is part 2034 is non adjustable and 2035 is adjustable. And anytime we recommend going with a offset bushing is when you are planning on running a bigger rear tire to give you more tire clearance. And I would suggest if you are using a aftermarket rear end or like mentioned before a bigger tire in the rear they will allow you center the rear in the wheel well and give you maximum tuning capability of the suspension. If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
We are talking about it! But at this point I am not able to give you a exact time frame on when they will be available. Sorry for any inconvenience. If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
