Lean Spike Driving Me Crazy
Old 11-27-2009, 11:21 AM
TXZ0603's Avatar
Default Lean Spike Driving Me Crazy
I got this weird lean issuse when ever I let off the gas then get back on it. Dosn't matter if I just let up a little or between gear changes. It spikes over 18+ AFR, car stumbles for a sec, then it resumes its course. Anyone mind taking a look and putting out some ideas?
2003 Z06
Forged 347
LS7 cam
60# Motrons
160 Thermostat
Twin Turbo
Meth
TR6 plugs @.030
I have been using the paste % half with the afr% error.
Not sure it this will help but here are my PID's:
AEM WB
([PID.2811]/0.480287467)+8.5
AFR % Error
([PID.2811]/.480287467)+8.5]-[SENS.121])/[SENS.121]
Heres an example
HPTuners
http://www.hptuners.com/forum/attach...7&d=1259336944 <--- SCAN
http://www.hptuners.com/forum/attach...8&d=1259336958 <---TUNE
http://www.hptuners.com/forum/attach...0&d=1259342116 <--- .CFG
Old 11-27-2009, 05:24 PM
TheGovernorZ06's Avatar
if it was efilive i could help sorry
Old 11-27-2009, 07:52 PM
JonCR96Z's Avatar
Well I can't get your custom PID to come up, but looking through the tune I see that you're not disabling CL. STFTs may be causing you some problems, also have you cleared you LTFTs?
Old 11-27-2009, 07:55 PM
TXZ0603's Avatar
That's my CL tune. I tuned it primarily in OL and reset the trims each time regardless. Im almost ( not sure yet ) thinking that possibly my injectors could be causing it, but I know my data is good for them and they are new.
Could DFCO cause this even though it is used for decel and mine is an acceleration problem?
AEM WB
AFR % Error
Old 11-27-2009, 11:56 PM
TXZ0603's Avatar
Well I noticed that I did not match my Default injector pulse to my min injector pulse when I added the new injector information. I am going back to OLSD for tuning with the new PW added to see what it will do.
Old 11-28-2009, 05:17 PM
TXZ0603's Avatar
Did alot of driving and logging and tuning today. I got it down fairly well in OLSD so I went back to CLSD. The spike came back. It has something to do with closed loop. I turned DFCO back on in the final tune and it only seems to have made it worse. I am boggled to say the least.
Old 11-28-2009, 05:31 PM
JonCR96Z's Avatar
Are you logging the O2 voltages and trims in CL?
Old 11-28-2009, 05:55 PM
TXZ0603's Avatar
Logging the trims
Old 11-28-2009, 06:33 PM
TXZ0603's Avatar
Based on a response in another thread regarding transient fueling, here are my spike at map vs temp and afr. How could i adjust map when the table in the tune does not go that low?
MAP (kpa)
Temp 181 183
5.7 18.62
7.1 16.42
8.4 18.42
8.4 18.67 17.93
8.9 17.9
9.3 18.83
13.3 18.58
15.1 17.89
16 18.26
16 16.13
16 17.77
16 18.62
17.8 18.67
Quick Reply: Lean Spike Driving Me Crazy
