Yellow sludge under oil cap?
um that looks like some major water contamination in the oil. I know a slight amount of yellow under the cap is "ok," but that isnt slight. I would check your oil and or drain it to see if there is any more in the pan quickly
That is I belive, and I don't pretend to know a lot, but I think that is moisture in the oil. Happens if you do a lot of short trip driving. Might be wrong tho. My old 97 had that start happening when I only worked a few blocks away from where I lived at the time.
