cold idle
Old 11-30-2009, 08:18 AM
Prin's Avatar
Default cold idle
Ok, I recently did more work to my ride. I did the whole forged rotating assembly as well as added a FAST 92/92 combo. Well, now, the car will not hold a cold idle. I replaced the IAC motor and still nothing. It will go dead if you let off the pedal. Once it warms up, I can hear a huge vacuum take over and the car then idles on its own. What do you guys think?
Old 11-30-2009, 08:20 AM
teke184's Avatar
the vacuum sound is likely just the added noise from the FAST intake.
i noticed it as soon as i put mine on....sounds like a vac leak...but it doesn't appear to have one.
Old 11-30-2009, 08:48 AM
Prin's Avatar
Yeah, I think that is what it is. But, what about the cold idle?
Old 11-30-2009, 09:28 AM
youguessit's Avatar
check to make sure the map sensor on the back of the manifold is not leaking vacuum. This could give it a hard to start till it warms up.
Old 11-30-2009, 09:30 AM
ramair21's Avatar
I just replaced my TB with a S3 polished TB. After i installed it i could hear my intake suck so much air, i thought it was also a vacuum leak. I had to use HPtuners to tune the Idle Airflow and IAC steps for start up since i was sucking so much air. I also installed the LS6 intake after the TB. You might be in the same boat i was in
Old 11-30-2009, 10:07 AM
kinglt-1's Avatar
Has it been tuned?
Old 11-30-2009, 10:29 AM
Prin's Avatar
Yes, it has been tuned...
Old 11-30-2009, 11:00 AM
teke184's Avatar
was the cold start tuned?
or just WOT and/or driveability.
mine has been tuned twice, and even with a part throttle tune, it surges all over the place at cold start. soon as it hits closed loop it smoothes out in seconds and holds steady at ~900rpm
Old 11-30-2009, 12:06 PM
Prin's Avatar
The cold start has been tuned. That is what puzzles me.
