TSP True Duals and Lowered Car? Will It Clear
my buddys car is a 2002 Z28 with Pacesetter LT TSP ORY and magnaflow catback, and he is considering going with the TSP true duals, but his car is lower with the Eibach pro kit (1inch drop) will it have any clearance issues other the the Ypipe now hanging low, how will it compare to the ypipe in regards to ground cleareance now on the car?
thanks
thanks
I would go to a good exhaust shop and have the custom made. I had tsp TDs on my car at stock height. ground clearance was okay. but was hell when i lowered it. I actuallt sold my tsp set up and had a custom setup fabbed up. exhaust shops can custom tuck the pipes higher. i gained a full inch of clearance. still scrape on massive speed bumps though.
We haven't had any issues on the TD's with BMR or Eibach Pro kits. If you take your time on the install and get everything tucked up properly, there shouldn't be an issue. However, you have to remember it is a lowered car so hitting every pot hole or going 50 over speed bumps isn't a good idea. But there shouldn't be too much of an issue when it's setup properly.
Jon
Jon
LSX Mechanic
It will clear, but you'll need to be very careful about your driving habits and more specifically where you drive. I've installed a few of these kits on lowered cars with no problems, but it's not uncommon for people to bash one of the bullets on something and put a dent in it.
Bottom line, due to the floor pan design there really isn't a such thing as "good" ground clearance on an F-body. That goes for TD's and Ypipes.
i had the tsp catted ypipe and switched over to the TSP td's and I actually gained ground clearance with the TD xpipe. I took my time and my buddy and I tucked it up real nice. The only area where its low is the exhaust tips where they dump at the rear axle. I've had no issues with clearance even though I'm at stock height. I could easily put a 1inch drop and be just fine.
Send me a PM and I can send you my pictures of my setup.
I have the Prokit and the TSP true duals and I really dont have any issues. My car is my DD and you will have to re-learn going over speed bumps and some dips in the road. The pipe coming from the drivers side collector leading into the x-pipe hangs really low and that the lowest part. Im either going to have a shop tweak it or add some metal spun cats to the system
Jon
As long as you pay attention where you're going and know what you can and can not go over you won't have an issue. We have customers buy these kits daily on their DD cars and have ZERO issues. It is a car, not a truck. If there is a dip in the road chances are you can't take it a 60 MPH. You have to slow down and go over it at a slower speed or slight angle. Most of the vettes and exotic cars rolling around are lower than these cars and get down the road just fine. It's all about how you drive them. You could bottom out the stock exhaust and drag it over speed bumps if you wanted to...
Jon
Jon
Like a previous poster said, I had the Texas Speed ORY on the car and then switched to their TD set up and gained ground clearance. I do have to watch it on big speed bumps or driveways with as steep transition. Also, I am sitting on the lower perch in the front on the Koni shocks and did the heater hose mod on the rear springs so I am a bit lower than stock. Not as low as the prokits will take it though.
Jon
Jon
i installed mine on garage floor with the help of my buddy. Used jack and jack stands and each of us worked on each side. Try twisting some of the pieces that run off the headers and you can gain ground clearance that way. Just be patient it will work!!!Also the xpipe piece has a right and wroing way off installing it. I don't remember which way but you can definately tell once its installed which is correct way. Hope this helps!!
yeah, i wish i had someone to help me work on my car. the best person i know for that is actually my wife, haha! my dad helped with the torque arm relocation but he's never worked on cars in his life and doesn't even know the right hand rule for wrenches. most of my friends talk like they know cars but are too lazy to actually work on one. anyways thanks a bunch to both of you and i will probably call you next weekend. the wife's gonna be out of town :lol.
