WTB: Lots of LS1/LS6 parts
All right, need some parts...What ya got? For parts that are Y-body/F-body specific (altenator bracket, oil pan, etc), I prefer all F-body
Valve covers
Timing chain (double roller...?
Timing chain cover
All gaskets minus head
Oil pressure sender
Water temp sender
All sensors really
Altenator/bracket (F-body)
Starter/bolts
Oil pan (F-body)
Windage tray
Pickup tube
Wiring harness/PCM (6 speed please)
PCV system (LS6...?)
Intake manifold (LS6...?)
MAF
Intake air temp sensor
Throttle body w/idle air control and throttle position sensor
Throttle cable (non traction control)
Coils/brackets
Fuel rails
Fuel injectors
1986 Corvette Radiator or something similar in size (27.5x19)
C4 Corvette aluminum driveshaft
Super fly shift ****
Probably lots of other stuff needed, so if anyone can think of anything, please speak up. This is just going off the top of my head.
If you didn't figure it out, it's for the RX-7. I have the motor (motor with no accessories, oil pan...blah blah...Just block, connecting rods, crank, pistons, heads, cam really), "transmission", clutch, flywheel, car, and that's about it.
WOO!
-Tyler
Valve covers
Timing chain cover
Oil pressure sender
Water temp sender
All sensors really
Starter/bolts
Oil pan (F-body)
Windage tray
Pickup tube
MAF
Coils/brackets
Fuel rails
Fuel injectors
WOO!
-Tyler
hey you need stock rx7 oil sensor and water temp for the ls1 to work with your stock gauges ..
but i do have the air intake temp and the double adj roller brand new . ill take $120 for both +shipping pm if your interested ..
do you need cetenter bolt valve covers or the 98 perimeter bolt covers ??
im a ls1 guy so i knw were your coming from !! lol .. pm if you need any of my parts
