If money were no object?
Old 12-01-2009, 08:35 PM
cabotgsxr's Avatar
Default If money were no object?
And you wanted to build the ultimate head/cam combo motor. And i know this is going to be touchy but still be able to drive it everyday. Here's the monkey wrench so to speak the bottem end must remain
TOTALLY UNTOUCHED!!!
WHAT HEADS AND CAM WOULD YOU BUY AND WHAT SPEC'S?
Old 12-01-2009, 08:40 PM
LS6427's Avatar
edit: Ported L92 MAST Motorsports heads and ported L76 intake with a 90mm whatever TB. Then change the cam, thats not bottom end.
Should be near 500 RWHP.
Old 12-01-2009, 08:41 PM
Pro52R's Avatar
1st and foremost.
DO A SEARCH
2nd. L92 heads will not fit on a LS1...unless your talking about the MAST Motorsports ones.
Old 12-01-2009, 08:47 PM
NemeSS's Avatar
Old 12-01-2009, 08:49 PM
greatskiiiier's Avatar
id copy Patrick G's setup
Old 12-01-2009, 08:50 PM
chavez885's Avatar
3/4 race cam and home ported stockers!
Old 12-01-2009, 08:52 PM
LS6427's Avatar
Originally Posted by Pro52R
1st and foremost.
DO A SEARCH
Oh ****, thats right....you need that 4" bore.
Ok...Mast L92's
Old 12-01-2009, 08:58 PM
KrisXpc's Avatar
Hahaha...
Old 12-01-2009, 09:34 PM
cabotgsxr's Avatar
See the thing is i dont want to just through a expensive set of heads and a big cam in my car. I want them to match and preform together. I was leaning towards a set of AFR 205's and a ms4, along with a ported fast 92/92? I was wondering if mabey a well known shop could chime in on this. I am going to be ordering H/C/I within the next few weeks and i would like to spend my money with a site sponsor.
Old 12-02-2009, 12:30 AM
Super Moderator
Reckless's Avatar
Why don't you let Texas Speed spec it for you? They only have the fastest heads/cam with stock bottom in the country.
Old 12-02-2009, 06:27 AM
toadzq8's Avatar
Buy a Audi R8 and be done with it!
Old 12-02-2009, 07:08 AM
ScrapinBye's Avatar
If money is no object, then Pat G's setup w/ a HARROP intake. From what i've researched, these intakes are supposed to be the best but cost over $3000
Old 12-02-2009, 07:46 AM
cabotgsxr's Avatar
ok i understand all about an expensive intake. but $3000.00? isnt that a little excessive?
Old 12-02-2009, 02:56 PM
MurderedOut's Avatar
excessive? i thought this were IF money were no object?
Old 12-02-2009, 03:14 PM
STG
STG's Avatar
Why is this in External Engine?
Old 12-02-2009, 06:55 PM
cabotgsxr's Avatar
the money doesnt matter but doesnt anyone think $3000.00 is way over the top for a intake manifold?
Old 12-03-2009, 03:16 PM
Marc 85Z28's Avatar
"If money were no object", then why stick with a stock bottom end, and complain about a $3000 intake?
And an "ultimate head/cam combo motor" would not have AFR 205s, an MS4 cam, or a FAST 92 intake like you suggested.
Old 12-03-2009, 03:48 PM
matt1289's Avatar
I would do -
https://ls1tech.com/forums/dynamomet...-500-rwhp.html
or
